You can make the special tool ion the cheap. Get a 12 point box wrench and heat and bend it so the socket end is flat with the shank. Cut the other end off and weld a 3/8 drive socket on that end. **Be sure the new specialized wrench is located 90 degrees to the beam of the torque wrench or your applied value will be inaccurate. Therefore, be sure of the location of the 3/8 drive socket before you weld it.
02 998 La Strega Bella
