How do you remove the rear brake master res insert? - Speedzilla Motorcycle Message Forums
Old 11-23-2009, 01:06 AM
mrgrn's Avatar
Default How do you remove the rear brake master res insert?
I have a little rear res and there is the plastic insert that allows the hose and i would like to get it out, any suggestions?
TIA
Mark
www.carbonpartz.net
www.blackdragonexhaust.net
Old 11-23-2009, 01:30 AM
demontech's Avatar
livin the high life
it has a square barb that is pushed into the rubber gromet, i pull up on it and spray some lube into it then wiggle it around to get the lube into it. then you just need to pull it to the side(it is a pain)
Old 11-23-2009, 01:42 AM
mrgrn's Avatar
super thanks
is there threadfs underneath by chance? reason i ask is i am using it for a different application and need to change the tubing size or install a fitting there
www.carbonpartz.net
Old 11-23-2009, 08:36 PM
demontech's Avatar
livin the high life
usually just a rubber insert
Old 11-30-2009, 03:13 PM
Send a message via AIM to TAftonomos
Pulls straight out, just use some force. I saw/wanted the thurston rear brake resi delete...but can't afford the $130 he was selling them for. Made my own little fitting on my southbend lathe, tygon 2075 tube, seems to be working/holding up fine.
I'd be more than happy to help you out with a fitting...
Old 11-30-2009, 08:35 PM
I bought a SB 9" about 15 years ago as it was virtually new and unused for 10 years. I can't tell you how much and how often I use that thing. I'm throwing out chips every couple weeks.
02 998 La Strega Bella
Old 11-30-2009, 11:47 PM
mrgrn's Avatar
One of those would work very nice!
i am using mine now for a thumb brake application and will be going to mu mini ISR and that has threads and really a male thread by barb would be best for that as well.
? though. i am going to be using this for the thumb brake and still use the rear. i am betting the need for the rear reservoir is nil. i was going to get a double banjo for the rear master and just find a threaded plug for the rear master reservoir, sound right?
www.carbonpartz.net
