Will 748 wheels mount on an 848? - Speedzilla Motorcycle Message Forums
Old 10-01-2009, 03:53 AM
Can Afford To Be Critical
Default Will 748 wheels mount on an 848?
A buddy of mine picked up an 848 at a rock bottom, gettin' outta town price. Only problem is the wheels were chromed. Yes, it made me ill, too.
Anyhow, he's in the market for a set of wheels and we were wondering if the bolt patterns, disc mounts, axle sizes, etc. were the same for an 848 as they are for a 748. Are they interchangeable?
Old 10-01-2009, 06:54 AM
Super Moderator
You can mount the 848 rear wheels onto a 748, thatīs a straight swap.
The front wheels should require 998R brake discs with less offset (I think it was 10mm instead of 10). Axle should be the same as I could mount a 916 wheel in my 999 and a 1098 wheel did fit as well. Would surprise me if the 848 had a different axle. Anyway, you could change the bearings if the axle wouldnīt fit.
The only thing you might worry about are the wheel spacers, but hey, thatīs shouldnīt be a problem, right?
Why donīt you get the 848 wheels powdercoated or painted?
Old 10-01-2009, 01:32 PM
998R's Avatar
Originally Posted by Ben710 View Post
The front wheels should require 998R brake discs with less offset (I think it was 10mm instead of 15).
I think this is what you meant to write!
Ducati 998R 463/700
Old 10-01-2009, 04:43 PM
We'd thought about that but there's a rumour that says the re-heating process of getting the chrome off and the powder coating curing process might weaken the wheel.
I'm totally without a clue on this stuff so if the assembled knowledge of this board can chime in it would certainly be appreciated.
Old 10-01-2009, 08:05 PM
Send a message via AIM to devilisht2003
You can mount 748 wheels up to a 848 and it's pretty easy. You have to use a 748 speedo spacer and 748R rotors. Also on the rear we've seen interference with a 5 spoke cast mag wheel. Here is a thread showing pics of 3 different wheels on a 848. 848 wheels please! - Page 2 - DucatiSpot - The Ultimate Ducati Forum
Old 10-01-2009, 09:28 PM
Thanks Devilish !
Old 10-02-2009, 01:58 PM
Just to make it clear: the 998/996/748 R - discs do have MORE offset, don't they???
That's what I remember...!!?????
Old 10-02-2009, 09:12 PM
CrimsonCloak's Avatar
Only interference I've seen on the rear is with 16.5 mags.
Also for front rotors 748/916/996/998/900ss/ST2/3/4 are 6 bolt 10mm offset if I recall.
748R are 6 bolt 15mm offset
749/999 are 5 bolt 15mm offset
Old 10-02-2009, 09:13 PM
748R HP rotors
Old 10-02-2009, 10:15 PM
Le Kiwi's Avatar
Chromed wheels...................
...Just when I thought it was safe to go back in the water......
Old 10-13-2009, 04:59 AM
Originally Posted by CrimsonCloak View Post
Brake Tech might have 5mm spacers, allowing "normal" Ducati rotors to fit. BrakeTech Motorcycle Brake Pads, Rotors, and Braking Products
Chris Kelley - or Ca Cycleworks staff
for tech info ::
www.ducatitech.com
to buy Ducati parts :: Ca Cycleworks :: www.ca-cycleworks.com
Old 10-13-2009, 09:08 AM
Puuuhhh....thx for that: finally I can sleep again at night !!!
Old 11-15-2009, 10:30 PM
Ducati23's Avatar
RC Slayer
I have used them without any real issues. Requires 748R/998R rotors. Yoyodyne stocks Brembo HP in this type.
Some brands or styles of rear wheels are very close to the rear caliper, in some cases a small amount of filing or machining or the back edge of caliper may be required for proper clearance.
Spacers for the front are required, easy to do and simple to fab up.
This is usually a small price to pay given how cheap mag wheels for the 748~998 can be bought compared to what 848 Magnesium wheels cost. I have bought 3 sets of mag wheels for the price that LP is blowing out one set of Marchesini 848 wheels on eBay right now. It is worth doing!
848RS, M1100S (soon)
Đ 2011, Speedzilla.com, Inc
