Rear Shock Disassembly Question - Speedzilla Motorcycle Message Forums
Old 07-02-2009, 12:54 AM
Default Rear Shock Disassembly Question
I want to replace the spring on my Monster 750 it is just too soft for my weight. Can I use a regular spring compressor like I use on a car or is there a special MC tool. Also, does anyone have an exploded view of how the shock comes apart? I realize this is not an expensive mod and it is easier to have a shop do it but I want to do it myself.
96 900 SS/SP
99 748s (lucy)Sold
01 Monster 750 Dark
"It takes big balls to ride a small bike!"
Old 07-02-2009, 11:26 PM
TrickLidz's Avatar
lidzduc.blogspot.com
http://www.ducati.com/doc/catalogue/...kie_Usa-02.pdf
easy enough. just remove the shock (support the bike from the frame) and remove the collars.
http://lidzduc.blogspot.com/
2003 999R #159
1999 ST2
1998 748
2006 R1200RT
Old 07-03-2009, 06:29 AM
Super Moderator
Does it have an external gas reservoir? You can´t undo the collars on the 748 Showa, because the stupid reservoir is in the way.
Old 07-03-2009, 03:23 PM
jhord's Avatar
Wind the preload collars all the way up, push up the spring and bottom spring seat, take off the circlip, voila.
Old 08-13-2009, 05:00 AM
banda's Avatar
Señor Member
On shocks that load the spring even when the collars are all the way out, a cheap spring compressor is a pair of ratchet lashing straps... not tie downs. Tie downs have hooks. What you want is lashing straps that have a free end that gets wrapped around the "cargo" and then threaded back through the ratchet.
So you feed that free end of the strap through 4 or 5 coils of the spring, then thread it into the ratchet. Do the same on the the other side of the spring with another lashing strap. Slip a piece of carboard or something between the ratchets and the spring so you don't accidentally scrape the spring when you tighten the ratchets. Go a couple clicks at a time on each side, and the spring compresses. When you're done, point everything away from your head, your kids, your dog, and your china collection - release the ratchet - it will go "pop", and then you just take the lashing straps back off.
Even cheap straps will put 150 pounds a piece on the spring with no problems - and that's more than enough to compress a MC shock spring.
Old 08-13-2009, 10:48 AM
hallo,
where do you get those parts catalogue?
do you have it from other models as well?
henk!!!
888 '94,916 '94,944 trackbike
Old 08-13-2009, 04:18 PM
Super Moderator
Ducati.com
Left hand side has older model years.
Old 08-13-2009, 10:07 PM
Originally Posted by Ben710 View Post
Ducati.com
thank you.
henk!!!
