Switch gear - Speedzilla Motorcycle Message Forums
Old 03-01-2009, 07:16 PM
vij vij is offline
www.virdung.net
Default Switch gear
Is a ST2/ST4 (2002) R/H handlebar switch gear the same as a 748/916/996? I am rewiring my 851 with 748 Harness and can only find a ST2/ST4 one.
Jocke............
MHR 900 1984
S4 984 2002
www.virdung.net
Old 03-02-2009, 09:37 AM
Le Kiwi's Avatar
Plugs are different from the 851, but it can be made to fit. If you're using the 748 loom, it's no problem.
From memory, the ST switch was all black, whereas the 916 one had colored switches.
Radio-Spares have the AMP connectors in stock.
...Just when I thought it was safe to go back in the water......
Old 03-02-2009, 10:46 AM
vij vij is offline
www.virdung.net
I am rewiring the whole bike as I am installing a S4R engine and the easiest way is to replace the whole thing so I got a 748 kit. The only thing that I am missing to do the whole thing is the L/H switch gear and I need the connector for the fuel tank.
Jocke......
MHR 900 1984
S4 984 2002
www.virdung.net
Old 03-05-2009, 02:32 PM
Your in France, you can buy the Domino switchs from Guido at Redracingparts.com (in Italy). I think they are posted under electircal switches. You can re-pin the connectors.
Old 03-07-2009, 07:17 AM
vij vij is offline
www.virdung.net
This switches looks nice. The problem is that it is the wrong connector. It is the same as on a 851. The only reason that I want to change switches is that I want the connector.
Any one knows where I can find this connectors that fits with a 916 harness?
Jocke........
MHR 900 1984
S4 984 2002
www.virdung.net
