Shock and Fork ID - Speedzilla Motorcycle Message Forums
Old 01-13-2009, 07:33 AM
Default Shock and Fork ID
I have searched this forum high and low and can't find a thread about this....
I have just acquired a 2005 999S monoposto, and I'd like to sort out the suspension while it's -30 up here! To that end I need to identify the Ohlins parts on this thing.
The Ohlins USA guys say that I should be able to find model stamps on the fork bottom and should be finding FG 315, but I cannot find the stamping.
Also, for the shock I think I'm looking for DU3260 on the shock cyl head but can't find that stamp either.
Also, is there a chart to help identify the Ohlins shock springs? I find 01091-19/70 L334 on this spring.
Old 01-13-2009, 02:29 PM
MultiDoc's Avatar
Check the inside of the lower fork leg (where the caliper goes) and you'll see it.
Can't help you with the shocks though
Old 01-20-2009, 05:58 PM
Good call on the fork ID location...
The shock ID location is on the flat surface of the cyinder head casting right below the mounting-bolt eye. It's a VERY small font stamping and it's obscured by the upper shock mount casting on the 999, but if you get in there real close.............
Old 01-21-2009, 11:43 AM
MultiDoc's Avatar
Glad you found them
