Originally Posted by motodave
It is well known that a low charged battery will cause the starter solenoid to stick on, happens all the time.I have this happen on Harley's, Honda's,Ducati's and even water craft. All the starter solenoid is small electro-magnet that will seize(either from low voltage or even just a bad unit) and the internal spring wont overcome the seizure causing the electrical system to continue to run on until battery if dead or cables to battery and starter are fried.
OK, I'll buy that! The reason the solenoid sticks then is because the low voltage caused the contacts to arc and "weld" together. I would replace the solenoid unless it can be taken apart and the contacts resurfaced or it's very likely to stick again IMO.
