engine oil cooler connector - Speedzilla Motorcycle Message Forums
Old 12-01-2008, 09:27 PM
woodmanr's Avatar
Default engine oil cooler connector
I'm trying to put an oil cooler on both my 748s and my 888. I have two oil coolers, one of them i believe is off a newer bike. The connectors on the oil lines are different. Does anyone have any of those black plugs that go into he engine, they look like big zerk fittings, that will fit the newer oil lines?
Wood
LRRS #853
94 888 LTD (red)
996RS (blue)
01 748R (yellow)
Old 12-02-2008, 01:05 AM
marvin's Avatar
I may have some but it will be a week or so before I can check. You might try posting on our 888 forum http://www.ducati851and888.com/
Don't forget the "flapper valve" that fits under the threaded stud that the oil filter spins on to. Also there are several different overhead oil lines depending on which cooler and two different sizes of banjos on the heads.
