Just recently solved a problem with my lighting portion of the wiring harness on my S4R (not same bike I know, but I am sure similar wiring). As it turns out, if there is no power to the gauge cluster the bike will NOT start. The gauges have to be there, and have to be powered. And yes, the fuel pump and fans will work, but the bike won't start without the gauges having power. The way I remember it: the power runs thru the lighting portion of the harness, to the gauges and from the gauges back to the ECU. I am sure there is a work-around out there, just not sure how (non-factory ECU probably). HTH
