50mm throttle bodies are used on both 748's and 916's. They're different in that in the bore below the throttle plate the 748 tapers to 44mm and the 916 TB tapers to 47mm (I think.) This changes the air flow velocity and fuel mixing characteristics to better suit the performance differences for the two engines.
Mine appeared identical to the 916 pair I bought, so perhaps the previous owner had already been in there.
They look similar, until you measure them. The 748 TBs have a 33MM long x 44MM ID straight (non-tapered) restrictor built into them (some where machined and some where cast, according to Sigma).
For an 853, it would probably benefit you swapping out the TBs. (Unless you have better luck than me with getting someone to bore them out - because I contacted all the major tuners here and elsewhere, and no-one was interested in boring my old 748 TBs for me.)
__________________ Old Baldy / WWBO #451
Ducati 996
Kawasaki KLR 650 '02
Kawasaki KLR650 '06 OB's Blog
I have bored the restrictors out in the past, you don't even need to disassemble the TB's to do it. (just clean the h*ll out of everything when you're done) Problem is it doesn't make all that much power diff. from what I have seen, on stock-cammed, stock-valved 853's anyway. Maybe a couple hp up top. Those stock tiny little valves and low-lift cams are the roadblock.
I'm pretty sure the two sets I had were identical in all respects, but I'll check again when I put the pro-thunder heads with the oversize valves in since that's probably when it will start to matter. Now to find some affordable SPS cams...
I haven't seen any around for a while. At this point, you may want to have someone burn you a chip that is similar to the Ultimap in terms of fuel and ignition. Then you could take some AFR measurements and have another chip made from there.
I just got a 996 FIM Ultimap from these guys, Silverback Ducati, and they everything from 851/888, 748/916/996 (with 853 included), and the ST series SilverBack
I was price shopping, and they were about 30% cheaper then BCM, and when i asked about it, they are BCM's chip supplier
