Friend's 01 st4 stumbles, sputters and then dies under heavy load/acceleration. Wait a minute or two and she goes again. She'll idle indefinitely but once you roll it on hard (in gear, not idle), she's out.
Wasn't bad gas. Electrical health (battery, charging, reg) is fine. Turned out not to be pump, filter, or cracked hoses inside (or outside) the tank. Verified this by swapping the tank w.my ST4's and problem persists, ergo why I'm posting now hoping for other suggestions.
Only other things I can imagine *may* - but not likely - have an effect:
- Oil may be a hair above full, though it's been run 30mi before this stalling began so wouldn't think it's anything to do w.overfilling
- Electrical issue that stalled the bike a couple mos ago - turn sig wires were loose, somehow causing some funky dash lightworks and some tugging seemed to 'fix' the problem, hasn't happened since, and besides - the stalling characteristics differ in that and current case so I doubt the loose wires shorting is it
Any thoughts or advice?
