If you have a monster, you don't have to drop the engine to remove the heads.
On my SS, I remove the front engine mount and loosen the rear (with a jack under the engine), and I can rotate the engine forward enough to remove the vertical cylinder head without dropping the engine (this is after removing pipes, carbs, chain, shock, etc.). - BrianK
