It appears that the cylinders have been re-Nikasilled, therefore the core plugs have been replaced. I would suspect those as the culprit.
You can also take a small amount (0.1 mm) from the cylinder or head to tighten the compression on the 'O' rings. Measure to be sure they are the right dimensions.
Those green 'O'rings are silicon, I think, but they don't get hard like the old Viton ones. I don't think it's a material problem, more likely a dimensional problem.
Doug
