Go Back   Speedzilla Motorcycle Message Forums > Ducati Message Boards > Vintage Ducatis
Featured Photos
by twick
Member Galleries
2090 photos
644 comments
by Pralientje
Member Galleries
2090 photos
644 comments
by Vitza
Member Galleries
2090 photos
644 comments
by injected
Member Galleries
2090 photos
644 comments
Old 05-15-2008, 04:48 PM
sideways sideways is offline
Dis Member
Default Fuel Pump for 750 Paso with Del'Ortos
Does anyone know the proper pump for this set-up. I believe it is a 4-5 psi. Does anyone have a part number that I could use at NAPA or something???? Thanks, Matt
Carrmoto
Ducati Indianapolis
Old 05-19-2008, 06:59 PM
Hedgehog Hedgehog is offline
Take a look at both the E2008 and the E2035. The E2035 is the correct one for my 900SS with carbs. Both are low PSI pumps, with the E2008 being 6mm longer.
Old 05-22-2008, 01:56 PM
Desmo Demon Desmo Demon is offline
Duc and Cover
Send a message via AIM to Desmo Demon
Ditch the fuel pump entirely. I have the same setup and the float bowls are lower than the bottom of the tank, so gravity feed is enough. I haven't run across any fuel starvation at higher rpms.
I also use a simple line routing and use the return line on the tank to act more like a vent to the tank. Here's my line route...
http://www.desmodemon.com/new_fuel_route.jpg
For all the Paso info you'll probably ever need: ducatipaso.org • Index page
2002 Ducati 748 monoposto
1998 Ducati ST2
1988 Ducati Paso (project)
1987 Ducati Paso 750
1985 Harley FXEF
Old 05-22-2008, 07:04 PM
DD,
Have you never run into an occasional problem starting? I don't know how different the Paso and SS plumbing is, but occasionally, my SS just wouldn't start. It took me a long time to catch onto the fact that sometimes the pump was running, and sometimes it wasn't. But, if it works for you without the pump, then 'nuff said. My old Airhead Beemer didn't need no steenkin' pump!
Old 06-17-2008, 05:50 PM
Duc and Cover
Originally Posted by Hedgehog View Post
DD,
Most of the time, the Paso starts so quickly, I can't even tell that the engine turned over any before it was fired. I also did a wiring mod (installing two relays) that is popular with the Paso that reduces the voltage drop to the coils that occurs with the OEM wiring arrangement.
1998 Ducati ST2
1985 Harley FXEF
Old 06-18-2008, 08:09 PM
Thanks DD
Old 08-10-2008, 03:34 AM
Dis Member
thanks for the tips. We ditched the pump but it is good to have the numbers for future knowledge.
Carrmoto
Ducati Indianapolis
