Lighter/smaller battery for the 610? - Speedzilla Motorcycle Message Forums
Old 09-26-2007, 12:45 AM
Default Lighter/smaller battery for the 610?
Anyone over here found a suitable replacement battery that weighs less than the cinderblock this bike comes with? That's gotta be a good way to shed 5lbs. It would have to be the same volt and amphrs but surely it's out there. Anyone?
'06 Husqvarna SM610
'02 Yamaha YZ426
'01 Kawasaki ZRX1200
Old 09-26-2007, 05:30 PM
CBR400RR's Avatar
I sell a lot of Yuasa YTZ7S batteries and on the RC51 it's 3.5lbs lighter and there $85.00 and I have had no problem for the last 3 years.
http://store.scottsms.com/
Old 09-27-2007, 04:55 AM
Just Riding Along's Avatar
I could not believe the size of the stock battery, it's at least an inch taller than the RC 51 battery!
Cranks better with the small battery too.
Old 09-27-2007, 11:53 AM
Which one, the Yuasa mentioned above?
'06 Husqvarna SM610
'02 Yamaha YZ426
Old 09-27-2007, 03:19 PM
You bet, the little Yusa.
Old 09-27-2007, 05:40 PM
So you're saying the Yuasa YTZ7S works fine in the SM610, not just the RC51? Sorry for the need to be so literal but I don't want to get the wrong thing and damamge my bikes elelctricals. Also do you know the exact weight of the YTZ7S? The stock 610 battery is 10lbs wet.
'06 Husqvarna SM610
'02 Yamaha YZ426
Old 09-27-2007, 08:36 PM
Here's the lowdown on the battery with thanks to the source, ROGUE (where the elite meet)
Battery Type: Yuasa YTZ7S
Voltage: 12
Capacity: 6
Dimensions: 4 7/16" x 2 3/4" x 4 1/8"
Weight: 4.6 lbs.
Metric Dimensions: 113mm x 79mm x 105mm
Amps: 0.6
C.C.A.: 130
It's meant for a WR450 I do believe and think there are others on SMJ running with it.
Old 09-28-2007, 04:37 AM
CBR400RR's Avatar
There both 12 volts and I have never heard of anyone having a problem running one, I have had one for 3 years and my electrical is just fine, let me know if you want one I can get them for good price.
Old 09-28-2007, 01:19 PM
The mechanic at the local bike shop told me if the C.C.A. (whatever that is) or the amphrs weren't the same, I'd either burn up the starter-motor or the stator would cook the smaller batttery (regardless that they're both 12volt). But it sounds like you guys got the proof there in front of ya so I'm going for it. How much we talking for this bat?
'06 Husqvarna SM610
'02 Yamaha YZ426
Old 09-28-2007, 04:12 PM
CCA = cold cranking amps. "Defined as: The number of amperes a lead-acid battery at 0 degrees F (-17.8 degrees C) can deliver for 30 seconds and maintain at least 1.2 volts per cell (7.2 volts for a 12-volt battery)."
Now it's got less CCA so in theory it should be tougher to turn over but it seems like the stock battery isn't the best one on the shelf so it rolls way better when you hit the button. I think a battery minder would be a must if you're an infrequent rider.
What's the output of the alternator? The 51 isn't cooking the battery.
Old 09-28-2007, 04:31 PM
CBR400RR's Avatar
That's why all bikes have a voltage regulator rectifier to control the voltage flow to the battery so it get what is needs, no more no less. I sell the Yuasa YTZ7S for $95.00 shipped brand new.
Old 09-28-2007, 06:19 PM
Family picture, Jr, Husky, and 51.
Foam to adjust for smaller size.
All tucked in.
Old 09-29-2007, 05:53 PM
Thanks for posting it up here and at SMJ BTW.
'06 Husqvarna SM610
'02 Yamaha YZ426
Old 09-29-2007, 10:55 PM
superbikemike's Avatar
Send a message via ICQ to superbikemike
Talking just good people....
Just Riding Along=just good people
He went out of his way to educate all of us, pics, definitions, went to the trouble of removing his batteries, to hook a brother up.......now that's what the brotherhood is about......
PS.........Quality work on retro fitting the new battery....
Old 10-01-2007, 06:16 PM
Thanks, and that is the idea behind these spots. It can get lost in all the purse fights at times.
