Help! broken rivets on on Ti Sato can - Speedzilla Motorcycle Message Forums
Old 06-14-2005, 04:19 AM
Default Help! broken rivets on on Ti Sato can
The two rivets holding the exhaust spring mount snapped off today. I have Ti cans. I guess I just need a rivet gun and the correct size rivets. Problem is, I don't own a rivet gun, nor have I ever used one. Could somebody fill me in as to what size rivets I need, where I can get a rivet gun and what is involved in replacing the rivets? Much obliged. Thanks.
Old 06-14-2005, 04:25 AM
if part of the rivet is still in there you need to drill it out. you can pick up a good gun for 40 bucks at most tool shops. just load the new rivet into the gun, stick it on the hole and squeeze it a couple times. pretty easy takes about 5 minutes.
Old 06-14-2005, 04:37 AM
Default Re: (KevinTX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KevinTX &raquo;</TD></TR><TR><TD CLASS="quote">if part of the rivet is still in there you need to drill it out. you can pick up a good gun for 40 bucks at most tool shops. just load the new rivet into the gun, stick it on the hole and squeeze it a couple times. pretty easy takes about 5 minutes.</TD></TR></TABLE>
Cool. Anybody have an idea on what size rivet is required? I'm pretty sure i remember reading a post about this...my lazy ass needs to do a search
Old 06-15-2005, 02:51 AM
just an FYI... found this post http://speedzilla.zeroforum.co...61398 Very informative & the perfect example of why I should have done a search first!!
Old 06-15-2005, 01:23 PM
Default Re: (Wrist Rocket)
That happened before on that bike. I called Dan Kyle and he shipped me new rivots and springs and the holders. I cant believe its happened again. He even sent me new rubbers and hangers too. Give him a call, he will take care of you.
Bruce
