Need Help Please...Quick Question - Speedzilla Motorcycle Message Forums
Old 06-11-2005, 03:48 AM
Default Need Help Please...Quick Question
What is the length of part 4 on http://www.ronayers.com/fiche/...10250
I would order one from honda but i need the bike ready for a track day monday. I guess it slipped my mind that both sides have collars and it must of fallen out when i was changing tires. I can make one as I have a lathe available but i need to know the length. I have the ID and OD from the opposite side collar just need the length.
If anyone could measure it for me i would sincerely appreciate it. Thanks guys
Old 06-11-2005, 05:09 AM
I really can't tell when it is on the bike what part is what, but I did measure 5/16" width on the right side, and 3/16" width on the left side {chain side}
I am not sure exactly what you mean by length?
If you have the OD-ID, I am assuming you mean width right?
I don't even know if what I was measuring is right, but I tried...
Old 06-11-2005, 05:33 AM
Default Re: Need Help Please...Quick Question (PeteDawg)
I can't view the Part 4 you had posted. Are you talking about the spacers for the axles?
If so I will post it tommorrow for ya
Old 06-11-2005, 05:54 AM
Default Re: Need Help Please...Quick Question (3stripes)
Old 06-11-2005, 03:20 PM
I'm sorry guys, Ya the width of the right side rear wheel spacer. thanks guys
Modified by PeteDawg at 7:58 AM 6/11/2005
Old 06-11-2005, 06:46 PM
anyone?...i'm in a bit of a bind here. I know its a hassle to remove your rear wheel for some guy you never met before but it seems like my only option to get the right width at this point
Old 06-11-2005, 07:13 PM
Default Re: (PeteDawg)
yeah its the right side spacer i think.... you wont be able to measure it on the bike as it drops into the seal....visible 5/16 sounds about right. might be different for diff years also....
so he needs somebody with the back wheel off to measure the spacer for him.... might wanna tell em what year yours is just to make sure. if its for an 00-01 i can pull mine and check.
Old 06-11-2005, 07:19 PM
Default Re: (iscrashingbad)
Thanks man, a buddy just came through in the clutch for me. Measured it up and it'll be milled in 5 mins. Thanks for your help anyway though man.
BTW I read your rant about life....things are gonna work out. Karma is on your side cause you would yanked that wheel off if i needed it. Take care,
