I'm trying to get the RC ready for a race this weekend, and I fear I might have screwed it up
'02 RC giving me an error code eight (blinks). I last rode the bike in a race in early April, and simply drove it off the track and into the trailer. I Changed the oil, etc., but I also attempted to remove the soft revlimiter per Rogue site, and noticed the problem when I pulled it off of the lift. Shoulda just unplugged the speedo
-- Engine idles, but cuts off as soon as I apply throtle. FI light is on, and jumping the service connector gives me an error code eight (TPS). I've pulled my PCIII out of the loop, but the error is still there. I've checked the connectors, and the circuit Ohms out, meaning I have continuity, but I'm not getting the voltages to the sensor that the service manual says I should. My assumption, then, was the ECU as I was jumping two connectors there. A local guy, I didn't know until last night, came by and let me try his, but same problem. My thoughts now are shorted circuit or possible TPS (again, I didn't get a voltage reading to it though).
Anyone know of a similar issue that can provide some help? It's either figure this out, or put a lot of tape and a Turkey pan under the 996 and bribe some Tech dudes at the track.
Your
would be greatly appreciated and I would be in your debt
