Which Power Commander? 3r or USB - Speedzilla Motorcycle Message Forums
Old 04-13-2005, 06:22 PM
Default Which Power Commander? 3r or USB
Hi,
My Problem. The original Power Commander i had fitted to my bike has expired(bugger) I now have the dilemma of which pc unit to re-fit. My bike is a 2000 sp1 with the following changes. Gas flowing and porting, full ti akra system, moriwaki airbox.
Please help.
Old 04-13-2005, 06:46 PM
Default Re: Which Power Commander? 3r or USB (nin73)
nin73, i installed a pc3usb, and it was pretty frickin simple. dont know how easy or hard the 3r is, but the instructions on the 51.org site for the 3r seemed sorta difficult, but the usb was different and really easy. hope this helps. clary
Old 04-13-2005, 07:19 PM
Default Re: Which Power Commander? 3r or USB (clarythedrill)
installation is not the prob as i will not be installing it. The dynojet engineer will be doing this. My question was more based around my tuning and which unit would be of more benefit to me due to the tuning.
I will also be having the bike set up with a custom map.
Old 04-13-2005, 07:21 PM
Oh and for anybody out there who is suffering from frequent backfiring I also had this problem and was found to be that the throttle bodies were loose!!!
Old 04-13-2005, 07:57 PM
Just seen a wide band commander. Do i need one of these as well as a pc unit or can i just purchase the wide band? Do i even need a wide band?
Yeah i know i really am that clueless I just fills her up and pulls the throttle!
Old 04-13-2005, 09:07 PM
Get the USB, it's software upgradable and you can use the Quick Shifter with it. You don't need a Wideband, it's used to measure exhaust gases.
Old 07-05-2005, 07:23 AM
Default Re: Which Power Commander? 3r or USB (SpeedKills)
Do the 3r and USB use the same maps? Why does the USB cost less than 3r if it's got more utilities?
Old 07-05-2005, 07:31 AM
Default Re: Which Power Commander? 3r or USB (Ex-998)
They are discontinuing the 3R as the USB is easier to use and will have more features, from what I was told.
Old 07-05-2005, 04:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ex-998 &raquo;</TD></TR><TR><TD CLASS="quote">Do the 3r and USB use the same maps? Why does the USB cost less than 3r if it's got more utilities?</TD></TR></TABLE>
The USB does not come with more features, it just has more upgrade capability.
The 3R has fuel mapping and ignition advancing features built into it. This unit cannot be upgraded.
The USB only has fuel mapping, but you can add the ignition advancer, quickshifter, and other goodies for an additional cost.
If you have only exhaust and free mods, the USB is more than sufficient by itself. According to DK, he only makes ignition adjustments at 10,000 rpm and above for the RC.
