JE piston - Speedzilla Motorcycle Message Forums
Old 03-21-2010, 11:53 AM
mighty max's Avatar
Default JE piston
If i wanna fix it the High Comp piston, can used the stock head gasket?
My RC51:Endurance race fairing,Hyper Pro 3D Rear Shock & Front Linear Spring,Hyper Pro Height Raiser Kit,Gp Pro Gear Indicator,Brembo RCS Master Pump,Turn1 Kevlar Airbox & CF Intake,520 Chain 15/44,Power Race Tyre,Rumble Undertray,Flapper Valve,Pair Removal Mod,Rockwall Clipon,HRC 1/6 Fast Trottle,EBC HH Brake Pad, Scorpion SS Slipon Race Can,Harris Rear Set, Carbon Stator & Clutch CF Cover, Samco Rad Hose,JE Piston...more to come...
Old 03-22-2010, 10:42 PM
From what I understand by reading many of these message threads, the JE high-compression piston with stock heads only raises the compression from 10.8:1 to 11.8:1.
That to get the full 12.8:1, you need the HRC race heads, which you'll probably never run across.
So I believe the OEM head gaskets should work fine.
If you are running aftermarket cams, it will be critical to check valve to piston clearances.
JD Hord or others may chime in for any corrections or additions if I'm in error.
Old 03-23-2010, 06:07 PM
gpz11's Avatar
Yes, the OEM head gaskets are fine.
'07 SV650, '04 FZ1, '02 RC51, '97 XR400, '85 XR4Ti
Old 03-23-2010, 06:34 PM
Trace's Avatar
Behind In His Steering...
I understand that the Cometic head gaskets add a little compression squeeeeeeze...anyone know how much?
Extreme Sealing Technology (EST)
2000 RC51 ~ 2000 VFR 800 ~ 2003 Z-06 (It's just a Chevy)
Old 03-23-2010, 06:43 PM
dstewart's Avatar
WSMC #51, CVRA #51
It will be closer to 11.4:1 rather then 11.8:1. Its not the heads, its the valves and the combustion chamber area the HRC Ti flat bottom valves use up that makes up the CR difference, 3.5cc difference iirc.
10.8:1 OEM
11.4:1 with JE Hi-Comp or HRC copy pistons
12.5:1 with JE Hi-Comp or HRC copy pistons with HRC Ti Valves or similar.
The OEM gasket will work fine for STD bore. Cometic makes a nice one as well that will accept +1mm over. The JE Pistons have deep valve pockets and you would need very hi lift (> +2mm) cams or very wrong cam timing to run in to P-V clearance problems.
Old 03-23-2010, 06:45 PM
dstewart's Avatar
WSMC #51, CVRA #51
The standard .027 gasket is the same as OEM. Use any other gasket at your own risk.
Old 03-24-2010, 01:10 PM
mighty max's Avatar
Were can i find Cheapest price to buy JE piston?
Old 03-24-2010, 03:47 PM
dstewart's Avatar
WSMC #51, CVRA #51
Call JD at HPR - Hordpower, Art of Twins
Old 04-21-2010, 12:23 PM
mighty max's Avatar
OK, my piston has arrived but there is no piston ring...
Can i used OEM Honda piston ring on JE piston?
Need help guys..
Old 04-21-2010, 07:32 PM
JetFxr's Avatar
Need help guys..
Yes, use OEM rings.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who would not."
"The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in Government."
Thomas Jefferson
