Wiring help help help - Speedzilla Motorcycle Message Forums
Old 11-20-2009, 04:44 PM
Default Wiring help help help
Im trying to wire my hotbodies undertail but the previous owner of the bike had the stock tail lights integrated. I cant fingure out this mess. I cant even find all the colors i need can any one help. Its a 2000 RC. any input will help
Old 11-20-2009, 06:06 PM
Follow the wiring diagram and sort out where the colors go to, if they have been moved about get them back to the standard, there isn't that many wires back there in the tail
Old 11-21-2009, 03:15 AM
Maybe this might help.
RC51 wiring <-------------> Hotbodies undertail
Brake lights = Grn/Yel <----> Red
Tail lights = Bl/Brn <-------> Blu
Ground = Grn <------------> Blk
Left rear signal = Org <----> Org (one for each signal)
Ground = Grn Same ground used on undertail
Right rear signal = Lb (light blu) <---> Org (one for each signal)
License plate light = Bl/Blk <-----> Separate light not part of undertail
Ground = Grn
All rear brake/running/signal/license lights essentially connect to same ground point on wiring harness.
