question on Brembo brake master wiring - Speedzilla Motorcycle Message Forums
Old 11-13-2009, 03:29 PM
ctdram's Avatar
Default question on Brembo brake master wiring
Ever since I switched to a Brembo brake master my brake light function has stopped working.
I do have the new pressure switch installed and wired up, but no matter which way I connect the wires my brake light stays on constantly. I know the brake light is supposed to stay on at a low level when the bike is on then brighten when the lever is pulled. My light is staying bright no matter what though. Even if I completely disconnect the pressure switch wires my brake light still stays at full brightness.
Anyone have any ideas? Have I confused everybody yet??
03 RC - Sato CF Banzai, PCIIIUSB, 15/41, flappered, PAIRed, soft-reved, steel braided
Old 11-13-2009, 03:47 PM
DesperateSP2's Avatar
Have you tried checking the rear brake switch? Try disconnecting that too and see what what happens.
Don't ask how I know that...
Old 11-13-2009, 04:02 PM
ctdram's Avatar
lol...that was it!
I just threaded the switch further into the rearset and that did the trick. Apparently the rear switch had tension on it constantly engaging the switch.
Thanks for the tip...didn't even think to look at the rear.
Old 11-14-2009, 10:37 PM
that may have been the fastest solved problem on this site EVER hahaha
