Originally Posted by Waldo
What does it take to convert an SP1 throttle body to an SP2? Do the heads have different diameter bores in the intake side? What about the ECU? Fuel pump?
You need SP2 throttle bodys and boots, a Thorsten/TurnOne style airbox and a Power Comander with a custom map. Thats it, the SP1 ECU will run the SP2 injectors just fine. Make sure the SP2 throttle body's include the sub harness for the SP2 injectors, it will plug in to the main harness with no problems.
The fuel pump is the same, the intake on the heads are the same just he rubber boots are different. The SP2 ECU has a different map (and a faster cpu but that really doesn't matter much) that can be easily corrected by a power commander and a custom map. The SP1 airbox wont fit with the SP2 t-bodies, but the Thorston/Durbahn style will work with either.
