CBR Radial Master feeling spongy??? - Speedzilla Motorcycle Message Forums
Old 11-03-2009, 08:08 PM
Ika-kun's Avatar
Sub-average Member
Default CBR Radial Master feeling spongy???
Hello all. From the get-go, my used master from an '08 1000RR has always felt spongy. The adjustment is on #1 and I can still seem to almost pull the lever in to the point where I hit my knuckles. What gives?
I have:
  • Flushed and bled the master and calipers with new Motul fluid
  • Installed Galfer lines and pads
  • Discovered NO leaks
  • the '08 radial billet calipers as well.
Does anyone else have this problem? Thanks for your time.
Old 11-04-2009, 11:58 AM
DesperateSP2's Avatar
That's exactly the same problem I had with my OE master cylinder on the SP2: it felt spongy from the moment I picked up the bike from my mate in Rome and no amount of bleeding or tinkering (including changing two brake levers) could solve the problem. I was about to take it apart to fully service it when I saw a nice Brembo radial master cylinder with a nice rebate at a local store and that settled the matter...
Old 11-04-2009, 12:26 PM
mighty max's Avatar
That..what im talking.............................
Old 11-04-2009, 06:40 PM
Ika-kun's Avatar
Sub-average Member
Thanks for the input fellas. I recently felt another '08 CBR and it too felt spongy, to me. Is this an inherent characteristic of the radial masters off the new Honda bikes? Or am I just bad at determining "feel"?
Old 11-04-2009, 07:19 PM
eppy01f4i's Avatar
Tough Crowd Racing #162
Send a message via AIM to eppy01f4i Send a message via Yahoo to eppy01f4i
They all seem to be that way, I know my 08 1000 is.
The best stock master I have felt is the Brembo units that come on R1/R6's.
Mark~
Tough Crowd Racing
Old 11-04-2009, 08:01 PM
watskooo's Avatar
I had the excessive lever travel problem with my OEM 2002 RC51 master cyclinder, and a 2005 CBR1000RR cylinder fixed it right up.
Old 11-04-2009, 10:11 PM
eppy01f4i's Avatar
The RC master is not a radial unit like the RR's so you will gain some additional firmness with that upgrade.
Mark~
Tough Crowd Racing
Old 11-07-2009, 06:17 PM
I dont know about the CBR master, but on the RC you need to bleed the banjo bolt on the master. Just apply a little pressure on the lever and just bearly crack the bolt.
Old 11-08-2009, 08:38 AM
watskooo's Avatar
One nice thing about the CBR radial master is the bleeder right on the master, so no need bleed the banjo bolt.
Old 11-08-2009, 02:17 PM
mrgrn's Avatar
Oddly enough my 06 R1 is the worst i have ever used and no matter what i can't get bite
putting a Rc51 front on my R1 or even the 04 CBR
www.carbonpartz.net
www.blackdragonexhaust.net
Old 11-08-2009, 02:18 PM
mrgrn's Avatar
you mean downgrade
the 51 has some of the best OEM brakes EVER i don't know why people think radial OEM cast junk will improve what already is awesome
www.carbonpartz.net
