HRC Hard Bite Pad Performance - Speedzilla Motorcycle Message Forums
Old 10-23-2009, 11:51 PM
1BadRC51's Avatar
I miss Vegas... :(
Default HRC Hard Bite Pad Performance
I'm new to using the HRC pads and noticed on a ride the other day that after a couple hundred miles of break in they started getting real loud. Pretty much a grinding noise and feel. They were still strong as hell but the noise and feel concerned me. When I pulled over to check them out there was nothing out of the ordinary, the rotors were smokin hot of course but that's it. So I guess I'm asking the guys who have used these pads if this is normal operation/performance for them.
2004 Honda RC51 (Gone), Sato Carbon Banzais, Black Sato Rearsets, Sato Frame Sliders, Scotts Damper, Ohlins R&T Forks W/ Superbike Valves, Ohlins Shock, Dan Kyle Link, Carbon Rad fins, Galfer SS brake lines front & rear, HRC Brake Pads, PCIIIUSB (DK Map), Vortex 42T Rear Sprocket, PAIR system removed, Flapper removed, Soft Rev removed, Corbin Seat, Puig screen, Rad Fan Mod, Undertail, CRG Levers, Vortex Clip-ons, Scotts Extended aluminum kick stand, Stomp Grip, Carbon Hugger, Shorai Battery.
Old 10-25-2009, 06:04 PM
mspeedman's Avatar
They should be a metalic pad, like the Race EBC GFA or EPFA compounds.I also get the wining and the gritty feeling when on the brakes soft but when needed metalic pads have the greatest initial bite compared to carbon comp. pads like the sbs or forodo. Sounds normal
You do however need to really clean the rotors to get the previous left over pad off the rotor surface to make sure they arn't just bedding against the left over compound that wears on the surface of the rotor. this should be recondnised as black residue on the rotor remove this to make sure the new pads are seating properly
Old 10-25-2009, 06:47 PM
Vitza's Avatar
Send a message via AIM to Vitza Send a message via Yahoo to Vitza
ive got the softbites and they grind like a mo-fo... really worried me at first so i did some hard stops where no one could hit me if i went down and they work like magic, no issues what so ever
00rc
Old 10-25-2009, 09:08 PM
1BadRC51's Avatar
I miss Vegas... :(
Thanks fellas.
