HRC valve springs, advancing cam gear timing? - Speedzilla Motorcycle Message Forums
Old 10-03-2009, 09:14 AM
DeepCmonkey's Avatar
Default HRC valve springs, advancing/retarding cam gear timing?
G'day all just have to say i have been enjoying reading this forum for the last couple of weeks and decided to join yesterday.
I own a 2001 sp-1 in Australia, it has a full Yoshi exhaust system and a pc2.
So far i have read a lot about the bolt on bits to make it lighter and a fair bit about engine mods, but has anyone experimented with adjustable cam sprockets yet?
Also if i decide to do a ground up rebuild with say a 13mm lift cam what springs would be recommended? (HRC or HRC copies) if available.
Cheers.
Old 10-05-2009, 07:32 PM
Darkest's Avatar
I cannot even begin to answer those questions for you, but welcome to the forum
06 RC51
93 VFR750
Old 10-06-2009, 07:42 AM
Default Cheers mate!!!
Love the bike....
Old 11-05-2009, 08:37 PM
g-man's Avatar
Send a message via MSN to g-man
Changing cam lift on a RC51 should only be done on a dedicated race motor and with a very clear understanding that if you use cast cams you will end up snapping a cam at some point. The same results are not uncommon if you raise the hard rev limit on the bike.
The best bang for your performance dollars is high compression pistons (if you are using JE keep in mind that they were originally HRC copies and require HRC heads to get to the rated compression figures), stage one cams, airbox, head/port work and finally doing everything you possible can to put the bike (and rider) on a diet. If you are going through this much, lightening the crank and rods is a must as well.
FWIW, adjustable cam sprockets are not required on the RC51 as the timing can be altered using a PowerCommander PCIIIr.
Old 11-05-2009, 09:25 PM
Trailing Member
I thought he was asking about cam timing,no?
"Life's what happens to you, while you're making other plans" John Lennon
Old 11-05-2009, 11:14 PM
dstewart's Avatar
WSMC #51, CVRA #51
+1
But here are some of my notes,
Billet cams are necessary to avoid snapping.
HRC Springs are about as good as your going to get, make sure to get the HRC retainers and HRC seats as well.
13mm is as much as the HRC parts will allow and I would not expect it to do so for extended periods of time.
Careful with the cam timing and additional lift, check for piston to valve clearance.
Old 11-06-2009, 04:12 PM
g-man's Avatar
True, but if you are already putting cams in the bike to change lift and/or duration the only other value degreeing the cams might have is to alter the timing of the spark in relation to valves opening and modifying the ignition timing is best handled with the PCIII.
Old 11-07-2009, 04:26 AM
dstewart's Avatar
WSMC #51, CVRA #51
PC3r is the only device that can change the ignition timing on the RC51.
Old 11-09-2009, 02:53 PM
I must be completely confused.
Does the spark trigger come from Cam timming? I thought it was crank timing.
Absolutely. I have one on my RC.
Old 11-11-2009, 12:12 AM
mighty max's Avatar
Which cam is the best? stage1 or 2??
Question: If i wanted to fix stage 2 cams, any parts to be changed also or redo?...etciston, gasket....????
