acumen gear indicator - Speedzilla Motorcycle Message Forums
Old 09-21-2009, 09:50 PM
Doughnut Spaghetti's Avatar
Moderator
Default acumen gear indicator
So I just installed a brand new Acumen Gear indicator on my 03 RC this one had a plug in harness so no wiring was required other than plugging it in. I'm having some issues programming the little Faker though.
I think I may have narrowed down the problem though.
The clutch master cylinder on my bike came from a RSV. Upon inspection of said clutch cylinder I noticed it has no clutch switch on it. Do you think this will cause a problem? I'm thinking the Acumen will never know that the clutch is engaged with out the switch.
It just blinks "1" when I try to program it and won't learn. Oh..I have the bike on a paddock stand and I'm keeping the tach between 2k and 3k like the manual says. Anyone got some info to share with me?
_______________________________________________
03 RC51
04 CRF450R Supermoto
Old 09-21-2009, 10:15 PM
watskooo's Avatar
I have the direct wired Datatool DIGI gear indicator installed and I removed the clutch switch before that and everything works ok. (Not sure how different the two are, but they can't be too different.)
I thought Acumen only had the direct wire gear indicator for the RC51?
Old 09-22-2009, 01:37 AM
Moderator
They sell harness's for the RC51, you just got to look hard. I found mine on Ebay, but I've seen seem for sale in the UK as well.
03 RC51
Old 09-22-2009, 06:03 AM
mrgrn's Avatar
yes they do i have one
i don't think that is the issue
email them they are awesome for servive
www.carbonpartz.net
www.blackdragonexhaust.net
