water wetter - Speedzilla Motorcycle Message Forums
Old 09-19-2009, 11:58 PM
Default water wetter
Just bought some water wetter in hopes of lowering my bikes temp. After I flush out the system....Whats the best way to use this stuff?
Old 09-20-2009, 02:21 AM
robfromsc's Avatar
Nice Member
After you flush, I just dump the hole bottle in, i dont carre what the directions say, Ive done this for years. Then to the top with distilled water, burp, repeat
http://www.onlinepaddock.com/
Old 09-20-2009, 03:58 AM
Thanks. I've heard that on this before. Just making sure.
Old 09-20-2009, 06:19 PM
biltforspeed's Avatar
Hate to burst your bubble, but the wetter stuff isn't going to lower your temps, certainly didn't for mine. I lived in AZ where lower temps would have significantly improved my riding, in fact for some strange reason it ran hotter, freak coincidence I'll never know, but I went back to the Honda coolant (needed to for sub-freezing temps here) and it ran just like it used to. The only bike-related change that has lowered my temps, is the new Power commander w/ the Dan Kyle Sato Banzai map, a little richer so worse gas milage but almost 5-8 degrees cooler.
The original idea to convert to the water wetter product was because I was thinking of doing some track days, that was the only benefit.
Old 09-20-2009, 06:37 PM
robfromsc's Avatar
Nice Member
works fine in the 4 bikes Ive run it in.
Old 09-20-2009, 06:50 PM
never tried a whole bottle at once, but I pour about 20 +/- or so capfuls in a gallon jug of distilled water (4 caps per gallon, plus a little extra). Shake jug, then pour it in the radiator....but thats just me
Old 09-20-2009, 08:36 PM
I run 50/50 with the DEI stuff to match the color of the Honda Antifreeze... Lowered it a few degree's
02 RC51 - Sold
08CBR1000RR - New Toy
Old 09-21-2009, 02:01 AM
Banned
1 whole bottle and your good
Old 09-21-2009, 04:29 AM
Can Afford To Be Critical
You could use the whole bottle OR you could follow the directions and have plenty for flushing your system every year for 3 years or so.
Using the whole bottle will not result in lower temps than if you use what is specified.
I could be wrong but directions are usually there for a reason.
But hey, if you want to use the whole thing, be my guest.
Old 09-21-2009, 03:40 PM
Southbound Pachyderm's Avatar
I followed the directions and have no issues for trackdays. Was running just over 200 on a very hot day at Road Atlanta (about 100 ambient!) and was a couple or more degrees cooler than my buddy on his Gixxer 600, and an SP2 that was running Engine Ice plus WW.
I use Honda brand in my street bikes, and have for years with zero temp issues. VFR with side rads and no fan mods.
Old 09-21-2009, 04:30 PM
bafflebrain's Avatar
I premixed with distilled water in a gallon milk jug and top up the rad. Just make sure you flush the system at least twice with water because coolant finds all kind of places to stick around. Mind you I have to get all coolant out because it is for my race bike. A little bit left over on a road bike should be okay.
As for better cooling I don't think it is any better than distilled water with a bit of oil to lubricate the water pump. Try Engine Ice if you want something that may do lower temp; at least it claims to do that.
Hope everyone using coolant replacement remember to changeover before the winter freeze.
Old 09-22-2009, 12:05 AM
Originally Posted by bafflebrain View Post
I premixed with distilled water....
I noticed a 4-5 Celcius drop. When its 20 degrees C out (70F), on the highway the thermostat is always in play. This Water Wetter sh*t works.
Old 09-22-2009, 12:45 AM
BRod's Avatar
Hate to burst your bubble, but the wetter stuff isn't going to lower your temps....
Your temp gauge isn't telling the whole story. It's only telling you the temp of your coolant, right? Water is better than propylene or ethylene glycol in transferring heat for two reasons: first it has a higher specific heat, which means it can hold more heat. There is more heat (energy) in one gallon of water at a given temperature than in any antifreeze that you can buy for your bike, or at least any that I'm aware of. second, water has a much better thermal conductivity, or ability to pick up and dissipate heat to another medium. So, water will pick up heat from your engine faster (which may cause it to be 'hotter') it will move a greater amount of heat to your radiators at a give flow rate, and it will dissipate more heat to your radiator fins so they can do their job. The system may appear to be running hotter, but the engine should really be running cooler. FWIW I'm not talking out of my ass and am willing to engage anyone on a technical discussion regarding heat transfer, thermodynamics or fluid mechanics. It's my background and like it or not, I get to deal with it often enough.
2000 RC51
2010 Husaberg FE570
Old 09-22-2009, 12:59 AM
robfromsc's Avatar
Nice Member
What he said
Dump in a bottle, top it off, burp it , ride.
Old 09-23-2009, 04:41 PM
Using a whole bottle is a waste of money AND it accelerates the formation of a white "film" that comes from the silicates falling out of the Water Wetter. This film is normal and is part of the corrosion protection that comes from Water Wetter, which is a good thing, but formation of thick layer of this film is NOT. Use it according to the instructions, that's what they're there for. You should get 3 radiator flushes or so from the standard bottle of Water Wetter I believe.
Old 09-23-2009, 08:15 PM
You obviously know what you're talking about, but I know what my bike's temp gauge has been reading for 5 yrs, maybe it isn't telling the whole story, but it's telling me a "number" everytime I ride regardless, sooo my point was a reference between the product Water Wetter and the Honda coolant, and I'll say it again, the Wetter product increased my temps.
Old 09-23-2009, 10:11 PM
robfromsc's Avatar
Nice Member
That's good. The stuff doesn't stay in any of our bikes for long, no more than season. I've pulled the motors apart after a couple of years of use and never had a spec of trouble. So if a bottle lasts you 10 years good on ya! I'm sticking to what's worked for me.
Old 09-23-2009, 10:55 PM
OK, so ignore the instructions, ignore the possible residue, and ignore the fact that you also lower the thermal conductivity of your mixture by using way more than is required. This essentially negates the positives of using Water Wetter in the first place. But if it works for you, good for you.
Old 09-23-2009, 11:51 PM
Not to be an ass, but at the dealer i used to work at, a fellow tech showed me the damage of just running water wetter with out flushes in 3 track only bikes (I see at least you flush the system so no prob here) and the white crystalization around the whole water pump was amazing. In fact those bikes were there for that reason alone, a compleate replacement of the whole water pump system. So RC51 crazed is right i would in my opinion run only what the directions say and from time to time flush the system and keep regular coolant in there for a while for proper lubrication, my
|^^^^^^^^^^^^^| |___
|--HONDA Racing-----| ||'|";,__.
|_..._...___________| ||_|_|...,]
Old 09-24-2009, 01:09 AM
robfromsc's Avatar
Nice Member
thats cool, but i had the motor turn open and its clean. i dont doubt what you say, but the fluids cycled out often, and i always flush with 2-3gallons of distilled. thanks for the heads up.
