Header Wrap - Speedzilla Motorcycle Message Forums
Old 09-15-2009, 03:28 AM
The Real MAN of STEEL
Send a message via AIM to Nukcrash69 Send a message via Yahoo to Nukcrash69
Default Header Wrap
Gonna be wrapping the headers.......what brand should I get.....I've seen 4 diff brands at the auto store?
Enjoy every day you are able to ride.....and ride ever day you are able to......For you never know what the next hundreths of a second will bring.
www.facebook.com/titanium7206
Old 09-15-2009, 03:13 PM
Banned
Any of them should work just make sure you soak em in water before you start wrapping. It makes it a whole lot easier to work with.
Old 09-15-2009, 03:32 PM
RVTMAVERICK's Avatar
TOP GUN Instructor
That's a neg. on the soaking part... "Lightly dampen" the wrap... other then that.. I'll say +1 with jgos929
Pat, JUST follow the directions on the box and you'll be goldin'
Most important part(s) of the process is...
#1)Let it DRY.. Completely after install\wrappin' is done... and
#2)USE High Temp. Paint on the exhaust wrap, After she's completely DRY.... Most Common I have seen is 1500degs., BUT there IS a 1800deg. paint coating out there... hold out for that.. I bought mine from Summit Racing and had it dropped off at my door.
It WILL Smoke like she's on FIRE when You first start her up,.. So... run it in short periods... I let mine idle for approx. 2 to 3min. and shut down... repeat acouple times going alittle longer run in times with increased RPMs.
The Exhaust Wrap brands: I don't think really matters but there's acouple different types and from what I understand... there's a "Copper" wrap that is supposed to hold even higher exhaust temps.
GL Pat... You can give me a call sometime if you'd like to talk about it or whatever.
And again bro., Great to see you're back!
Peace Jeff
PS. check out my thread: runnin' exhaust wrap, pictures in the gallery.. here> Runnin' in> Exhaust Wrap "Paint"! HAhahahaa
Peace Maverick
Old 09-15-2009, 06:54 PM
Thanks for the help guys.........those that know me.......know I just getting back in the game..........trying to get my a$$ to the track before it gets too cold here....
Old 09-16-2009, 12:53 AM
Area 51's Avatar
Be careful with the wet wrap. Once it's wet the adhesive stuff will get on anything it touches, and it likes to stay there. Wear some gloves and watch the swing arm. FYI, some people just do the rear cylinder pipe since it's close to the shock. The front is pointless, IMO.
"...let us not ignore the truth among ourselves, that we are the aggressors and they defend themselves. The country is theirs, because they inhabit it, whereas we want to come here and settle down."
David Ben-Gurion (the father of Israel)
"When fascism comes to America it will be draped in a flag and holding a cross." Sinclair Lewis
I pledge allegiance to the flag of the United States of America, and to the republic for which it stands. One nation, indivisible, with liberty, and justice for all.
Old 09-16-2009, 04:48 AM
Wrapping the entire length of the pipes benifits power and engine operating temp. Wrapping the front will reduce the engine bay temp and that helps overall engine coolents temps. These bikes have enough problems with running hot from what I hear.
Old 09-17-2009, 07:29 PM
texasixes's Avatar
Ride RED or go home
Default not good
rogue.org advices against ANY pipe wrap unless you want to replace pipe prematurely.
I'm not a Gynecologist, but I'll take a look.
Old 09-17-2009, 08:20 PM
Banned
Rogue is full of crap and I want my $20 back.
There are people that have gone years with their headers wrapped and have had no problems.
Old 09-18-2009, 01:17 PM
mrgrn's Avatar
years
i can get a whole header done in semi gloss black or silver ceramic coating for $200 too
www.carbonpartz.net
www.blackdragonexhaust.net
Old 09-18-2009, 02:17 PM
Area 51's Avatar
Probably because the higher temps inside the pipe can lead to cracking of the stainless steel.
Old 09-20-2009, 12:02 AM
I plan on getting some from DEI. I hear it works really well. They also sell a spray to apply to the wrap after you install it to make it last longer. Im so tired of roasting my nuts on this thing. I will do anything to lower the heat on this thing
Old 09-20-2009, 12:18 AM
mrgrn's Avatar
ceramic coat it then. the wrap is nice(cheap) but the ceram lowers skin temp to nearly nothing and there are many choices for that
www.carbonpartz.net
