water pump inspection hose issue - Speedzilla Motorcycle Message Forums
Old 06-05-2009, 03:09 AM
Vitza's Avatar
Send a message via AIM to Vitza Send a message via Yahoo to Vitza
Default water pump inspection hose issue
ive got oil leaking out of the water pump inspection hose... checked the manual out and its suppose to leak coolant if there is an issue w/ the waterpump but ive got oil coming out of the hose... gonna take the pump apart and try to figure it out in the next couple days but just wanted to know if anyone's ever ran into this before and has any tips... bikes got 56k miles
00rc
Old 06-05-2009, 06:23 PM
sbk_drew's Avatar
Definitely need to pull the water pump and rightside case cover to inpsect the seal to verify that it has failed or not.
You'd expect water to leak though....hmmm.
Old 06-05-2009, 09:47 PM
robfromsc's Avatar
Nice Member
It would seem like the oil seal on the pump is bad, if I remember right, I just changed my seals and I think at the pump there's 2 water and a oil seal right at the impeller. I wouldn't freakout. Just pull the case side and see, I had my local shop press in the seal, I removed the case and the whole thing, parts and all was under 100.
Do you have a manual? If not pm me your email address and I can scan the water pump pages for ya.
http://www.onlinepaddock.com/
Old 06-05-2009, 10:18 PM
DesperateSP2's Avatar
Are you 100% sure it's oil?
Last year, at the height of the Great Cooling Crisis, I noticed a brownish liquid coming out of the inspection hose.
It wasn't coolant and it surely wasn't oil. It was just dirty water.
Whatever it was it stopped after a few droplets and to be honest I haven't worried about it ever since.
Old 06-06-2009, 05:02 AM
Vitza's Avatar
ya is oil, feels like it and smells like it...
so should i replace the bearing as well or just reuse the old one? (if i can get it off w/o damaging it
00rc
Old 06-06-2009, 01:01 PM
robfromsc's Avatar
Nice Member
They tried to get me to replace the bearing in mine also, I didn't. I'm at 26k.
Do you have to pull the bearing to get to the seal? Didn't think so...
Old 06-06-2009, 02:26 PM
If I remember correctly you need to take the bearing off to get to the oil seal but again I could be wrong. If can take it off without damaging it why not reuse it?
You'll need both the mechanical seal (part number 19217-MAL-300, no point reusing the old one) and the oil seal (part number 91201-148-003). Should you need a bearing too part number is 96100-62003-00, water pump case gasket part number is 19226-MCF-000 if you are feeling the need to change it.
Old 06-08-2009, 02:25 AM
sbk_drew's Avatar
The bearing would prob be ok to reuse but if it were mine I'd replace it anyways while I was at it and I believe it isn't too expensive.
Old 06-08-2009, 06:00 PM
Vitza's Avatar
ya i just ordered all the parts... hopefully ron ayers wont take almost two months to deliver them like they have before
00rc
Old 06-08-2009, 06:34 PM
sbk_drew's Avatar
Are ya gonna try doing it all yourself or are you taking the cover in to a dealer?
Old 06-08-2009, 10:51 PM
Vitza's Avatar
gonna be doing it myself, seems like a pretty easy job... also gonna be rebuilding my calipers lol
00rc
Old 06-08-2009, 11:22 PM
robfromsc's Avatar
Nice Member
Do you have the press for the seals?
Old 06-09-2009, 01:25 AM
Vitza's Avatar
yup a buddy has one (hopefully still does as i havent talked to him in a while)
00rc
