jardin 2 in 1 full exhaust - Speedzilla Motorcycle Message Forums
Old 06-04-2009, 05:41 PM
borislav's Avatar
Default jardin 2 in 1 full exhaust
Anybody who has or had this set up what kind of experience you have with power,PC maps and fitment.Crashed my sato low's now i need exhaust.
THANKS!
Old 06-04-2009, 09:55 PM
johnyisthedevil's Avatar
chimp on my shoulder
check out the exhaust reviews over on RC51.org there is a very comprehensive write up of a bunch of different pipes including the Jardine 2 to 1.
94 vfr 750 cafe project
Old 06-04-2009, 11:41 PM
Banned
Only problem with the write up at 51.org is its old. I have a 2:1 gp setup and I haven't found a map yet that it runs right on. I've gotten it to run good but I believe there's alot more there. With the 2:1 I noticed it feels alot stronger up top but feels weaker in the mid-range. I just got an airbox and snorkel so I'm shootin for a custom tune in the next few months to bring it all together.
Old 06-05-2009, 08:59 PM
Marxist's Avatar
Doode - you need to get a map of your own - don't cheap out now... Nothing will fit you bike properly - trust me I know...
Besides dyno's are fun!
Old 06-05-2009, 09:16 PM
watskooo's Avatar
Existing PC maps are definitely the weak point, there are workable ones to be found with some effort, but I'd definitely say a custom map on a dyno is even more important for a 2:1 exhaust than with one of the more common 2:2 setups. Now if only the local guy would get his dyno shop back together I could follow my own advice.
Old 06-06-2009, 03:53 PM
The “experts” will tell you that they are not as good and don’t make as much power as the 2 into 2 systems. They are probably right to some level. The Sato systems do make more HP. But personally I was more interested in shedding some weight even if I lost a few HP at 10,000 RPM. I think considering the price and weight of the Jardine 2-1 they are a very good setup. I have no complaints at all with my system. They run fine with some of the 2-2 maps but obviously not as good as it could with a custom map.
I would find a used one cheap with a bad can and get a GP can. It will be load but so what.
Old 06-06-2009, 08:38 PM
the only place that they realy seem to loose out is the mid range. they usualy have a pretty decent dip around 5k if I remember correctly. overall though i think they have some decent gains. nothing spectacular, but decent. just watch out for the bracket that tends to break. there are some good pictures over at rogue. I know the write ups are old, but neither the bike nor the pipe have changed. there may be some better maps out there now though.
Old 06-07-2009, 12:01 AM
mrgrn's Avatar
the dip comes from too small a header out the head and not having a tuned length pipe on the rear head
if you bend the rear tube more and make them larger then it might not have so much a dip. the rear pip on that 2-1 is so short compared to the front
take a tape to them and see
www.carbonpartz.net
www.blackdragonexhaust.net
Old 06-07-2009, 05:00 PM
bryanboonern's Avatar
Let me know what you find, cause I just got a 2:1. I have a stock airbox and snorkel, however.
2002 RC51 Elka Triple Clicker Rear Shock, Jardine RT-One Ti slip-ons (street), Jardine 2:1 CF (track), PCIII usb, Scotts Rotor Damper, Fastline SS Lines, HRC Hardbites, 15/42 Gearing, Flapper mod, Pair mod, Soft Rev, Bladerunner Mod, Speedohealer, Sato knock-off rear sets from Thailand
1997 Yamaha Warrior 350 with Yosh pipe and lots of mods....FOR SALE $1500
Old 06-08-2009, 01:11 AM
They work fine overall. I've had them on for years. They do have a dip but you probably won't notice too much. The two biggest issues with them is that the tab did break (twice), was rewelded twice, should be fine now, (due in part to thin wall tubing and the mounting hole not having enough play for fitment). The other issue, which is more of a pita then anything else, is that the pipes blow the packing material out in a very short amount of time. The can will be empty in just 2000 miles, (which makes them sound tinny). On the positive side, I do like the looks of the single muffler over the doubles and the weightloss for this system is unbelievable.
I'm currently running the Erion 2into1 map and that seems to work ok for now.
Old 06-08-2009, 01:16 AM
mrgrn's Avatar
nice feedback, thanks for posting
www.carbonpartz.net
Old 06-08-2009, 03:48 PM
Banned
Does this mean I have to pull apart my beautiful black dragon can and repack it??? Dad-gum-it !!!
Old 06-09-2009, 01:24 AM
mrgrn's Avatar
naw, raw dawg it
www.carbonpartz.net
