Guys,
Just a refresher here, the previous dishonest owner (rsxjosh) who sold me the bike being in excellent condition had actually had the chain come off and blow out his cases around the cs sprocket. I found out after the purchase. Its been a long legal process and he won the initial round, but it ain't over yet.
The bike is an '05 in excellent shape otherwise and I don't want to install some junkyard motor with unkown miles or condition. If I do the motor work myself I will know it was done right, assuming I take the time to do so.
Anyway, I got a set of cases for my bike to swap the rest of the internals into. I noticed some scoring in the bores and would like the opinions of some of you experienced motor builders.
I originally thought I might be able to just have the bores lightly honed and then put in new pistons & rings.
To investigate that, I took the cases down to Fastline Cycles in Fremont, CA and talked to Alex there. From what I was told Honda uses a high-silicone aluminum alloy and the cylinders are not Nikasil. Some sort of special honing stone must be used for example. He said my options were either bore and hone 25mm oversize for $325 or have the bores cut slightly then nikasil back to standard size for $435.
Pictures of the scoring are below. They don't feel very deep and barely catch a fingernail. I haven't had a chance to mic out the cyls to see if they're worn, but there's absolutely no ridge to be felt from ring wear at the top of the bores.
Thanks in advance for the replies! Hopefully this condition had been addressed by someone already. The cases are in good shape otherwise.
