removing coils for on wire coil? - Page 6 - Speedzilla Motorcycle Message Forums
  #101 (permalink)
Old 06-30-2009, 09:15 PM
OB6D's Avatar
Originally Posted by OB6D View Post
I like this idea. Think i'm gonna adopt it. Wonder if these could do. They're VW, Audi, Seat, Skoda etc and like 30 Euro's new. Should be easely obtainable...
Here's some info, it didn't all sink in in one quick pass, but i guess it'd be tricky:
http://www.s-cars.org/postnuke/downl...structions.pdf
Ohw well:
It has 4 pins:
1-Power to primary
2-Ground for build in power output stage (POS)
3-5V DC signal from ECU to control POS switch
4-Secondary ground
Thought it would maybe be possible to supply 5V Vref to no. 3, then ground no. 2 through the MicroSquirt.
The standard stuff on the RC works different. The ECU controls timing and there's two wires running from it to the CDI amplifyer box, which i guess are cylinder #1 and #2. But i don't know if that's a 5V signal, but, if so that might work i guess. (CDI box dropped since it's functions are build in to these coils?) I dono...
I'm gonna forget this, sorry for hijacking.
IF you get two of these stick type coils with built in amplifyer.
AND the signal from your ECU to your CDI box (2x (front and rear?)) is a 5V DC signal too. Why not?
THEN there is imo a good chance these work with the RC and you could drop coils and CDI box.
Or if it's broken this might be fun to try.
  #102 (permalink)
Old 06-30-2009, 10:40 PM
It's funny that you brought this post up as I'm doing that conversion to my 93 UrS4 next week. It is turning into my new money pit, my RC just saw the light of day 1 week ago. But I'm looking at using the CBR coil stick instead as they handle the heat far better than the VW/Audi coils.
  #103 (permalink)
Old 07-01-2009, 09:48 PM
OB6D's Avatar
Hmm. And why do they handle the heath better?
  #104 (permalink)
Old 07-02-2009, 12:42 AM
If you look under any VW/Audi site you'll see many write ups about coil pack failures do to heat. The 1.8T coil was the earliest to be modded to the URs4, but due to the high heat they lasted only a very short time. The bike coils seem to handle heat and vibration alot better, so that's why I'm going that route. As for why they handle the heat better, I'm guessing better design (made by Denso).
  #105 (permalink)
Old 07-02-2009, 07:40 PM
OB6D's Avatar
Guess you're right, i've searched around a bit and i found me two of these VAG things. They're made in Italy....
The reason i wanted these is because of the built in amplification. I will use em with the MicroSquirt, not the original setup. Also i know the dwell times for these, it's nice to not have to guess about it. And these fit the original spark plugs with that screw thingy that cannot be unscrewed attached.
The plug to seal length is briliantly the same as from the original plug and cap. Only the heads are bigger and don't quite fit the valve cover, specialy not the front. But i've been told there's short and long versions. I hope these are short.
Ohw well, it'll keep me of the streets i suppose...
  #106 (permalink)
Old 09-18-2009, 11:12 AM
can anyone tell me what specs i need to turn the NGK plugs down so i dont have to buy a 600rr plug to compare! i was going to try the denso's but i have access to a lathe anyway, and i can only get them for £40 and the ngk's i got for £10
  #107 (permalink)
Old 09-18-2009, 05:01 PM
CBR400RR's Avatar
I have the coil kits in stock and I have been running one on my bike for almost 2 years with zero problems. I also have replacment Denso plugs in stock for $11.00 that you don't have to do anything to.
http://store.scottsms.com/
  #108 (permalink)
Old 09-18-2009, 07:27 PM
Waldo's Avatar
How much are the kits going for?
Fast bike slow rider
  #109 (permalink)
Old 09-18-2009, 07:49 PM
And i would have bought a kit from you, but i got these bits very cheap from a local breakers, already got the coils, the loom to modify, and a new set of ngk plugs, plus ordering a set of spark plug from across the Atlantic seems a little ott! just need the size to lathe the ngk plugs down to. i can work it out if no one know off the top of their head, just thought it would be easier to ask
  #110 (permalink)
Old 09-18-2009, 09:05 PM
CBR400RR's Avatar
The end is 3.77mm with threads and 8mm long.
  #111 (permalink)
Old 09-18-2009, 11:56 PM
Cheers mate
  #112 (permalink)
Old 09-22-2009, 03:38 PM
metalscorpio's Avatar
this thread is like a gift that keeps on giving
Hardchargerracing.net
