Old 01-22-2007, 08:50 PM
white rice white rice is offline
Default wtd: SP1 PCIII Usb sato banzai map.
i've looked around, and i couldnt find this so i was wondering if it even existed?
please help my dumb ass out.
Old 01-22-2007, 09:34 PM
beaugator beaugator is offline
Catcan'tscratchitmember
I didn't think they made bonsias for the SP1...just the "high" mounts which are different than the bonsias.
08 Ducati 848
CCS AM #263
Old 01-23-2007, 12:16 AM
yes you are right, but i have an sp2 header and that will make them fit onto an sp1.
Old 01-23-2007, 01:28 AM
EvilTwin-05 EvilTwin-05 is offline
Anger managment patient
But the throttle bodies are larger on the SP2. So the map will need to be custom made for the SP1 throttle bodies and the Banzais.
Old 01-23-2007, 04:28 AM
varium varium is offline
Meh, wouldn't it just run a little rich? Not such a bad thing longevity sake.
Old 01-23-2007, 02:09 PM
I am not sure about the rich running or not. The maps just add X% over the stock ECU A/F chart. So the smaller injectors and T bodies can only flow so much. To add to this the initial ECU A/F chart of the SP1 is different from the SP2. So for the sake of this lets say the SP1 sends 50CFM of fuel @5k RPM and the SP2 with the larger T bodies and 12 hole injectors send 75CFM of fuel @ 5k then the PC adds 5% to the SP2's stock A/F chart you end up nearly 30CFM shy on the SP1 than the SP2. Even if you knew the differances at each RPM and modded the map you would need to account for the injector size and its ability to get that vol. of fuel atomized. Rich or lean in the end we still are left with a bike that isn't running an optimized map for the increased flow and decreased back pressure of the Banzai's. So I guess the point is if you want a preformance exhaust to do what it was intended to do then a suitable map should be used.
Old 01-23-2007, 07:34 PM
so to makes things simple on myself, do you recommend that i buy 02 up throttle bodies and ecu and go that route? is that all i would need to convert it?
Old 01-23-2007, 11:54 PM
Yuppers to be done right or run the high mount SP1 map and call it good enough.
Old 11-19-2007, 10:08 PM
Vitza's Avatar
Vitza Vitza is offline
Send a message via AIM to Vitza Send a message via Yahoo to Vitza
any update on this? anyone w/ an sp1 and banzai's get a custom map done? your sharing would be greatly appreciated
00rc
Old 11-19-2007, 11:52 PM
thatkindasux's Avatar
thatkindasux thatkindasux is offline
Send a message via AIM to thatkindasux
i have an SP1 and need also sato banzi map..
Old 11-20-2007, 03:07 PM
Vitza's Avatar
no one has an sp1 w/ banzai's?
so i guess i could understand how no one made a custom map, but what maps are you guys running w/ the above mentioned setup
00rc
Old 11-20-2007, 05:47 PM
Dansrc51's Avatar
Dansrc51 Dansrc51 is offline
you're not Irish...
Send a message via Yahoo to Dansrc51
How many of you are running sp2 pipes on sp1's? my guess is this is purely asthetic as the Rogue site claims higher hp's with low mount set up.
argue on the internet?
Old 11-20-2007, 05:52 PM
Vitza's Avatar
well ya ofcourse its more aesthetic than peak HP gains, but im just looking for a sold map that wont run too lean or too rich and no flatspots... wishful thinking for a non dyno tuned map huh? lol
00rc
