Nice job for both you guys
I like how you disigned it to cover up that tiny bit of subframe under the seat. Can't wait to see it done man it looks sick
thank you and Mark copied it into carbon all the way to the letter.
OH SNAP, that is the best freakn idea (undertail) I have seen. I had a tweaked out subframe that I was gonna hack up just like that and use a race tail on it. I wish someone would've thought of this sooner before I sold everything.
I installed the tip over sensor on the bottom of the lower rail before wrapping the tail section with this materia. that material is what's used on boats for storage or transportation; this plastic when heat applyed, it shrink and gets thighter around whatever it covers.
once heat was applyed, here is what it looked like
took it outside and got busy for the first time with fiberglass and layed two sheets over it...let it dry and cut around it (should of used carboard instead of concreate floor)
once i removed it from the mold (tail itself) this is what it looked like
got busy with some bondo and got it kind of smooth on the outside..
Incredible build!!! Man, knowing and seeing what one can do with the RC as she gets longer in the tooth, I have no reason to ever move on...inspirational!
thank you very much.
is like i told people in the past, i always wanted an RC and had all kinds of other bikes but now that i got one, i'm going to make it my own.
not to thread jack but mrgrn ur inbox is full. I have sato cans i want to use that have an inlet of 2.135" and my two bros mid pipe is 2.010". Is there an adapter to close the difference? Thanks!
