Originally Posted by crashm1
My plan at this point is to drop the forks back to where they were and soften the rear preload to the 3rd notch from the bottom( now at 5th) with compression and rebound settings at both ends at the stock settings and then fiddle. Any suggestions?
"Softening" the rear preload, as you put it, is increasing rear sag. You need to set sag on the front and rear properly, and stop "guessing"
Front = 38mm
Rear = 20-25mm
There's a thread that was just started on this, that has links to 2 decent instructional articles on HOW-TO do it properly.
I can help ya with the sag setting, but you're on your own with the 2 friends.......
