Originally Posted by ceri shepherd
Can i get a bulb that fits the dip light that will give me a dip and headlight beam? i understand that i would have to run a wire across from the headslight lead to get this to work but i guess that should not be a problem.
Ceri,
The RC51 has H7 Bulbs, with adapters to fit the H4 plugs. Get an H4 Bulb, and trim the base smaller to fit in the H7 housing. (the size of the metal disc that fits into the light's housing) Figure out your Low and High beam terminals and wires, and make sure the bulbs filements are horizonal when you install it.
I did this on mine a long time ago, when I used to ride on the steet. If you search, I did a write up on it. The base can be trimmed carefully with a pair of tin-snips, or something of equal cutting strength.
