Sato GP (Short) Shifter Installed - Speedzilla Motorcycle Message Forums
Old 06-19-2006, 02:59 AM
nickbee's Avatar
Default Sato GP (Short) Shifter Installed
Don’t mind the hazy pic, I took it tonight in my dark garage and it was washed out a bit by the flash.
I installed the Sato GP shifter (Thanks Scott) in normal configuration. My main reason for getting it was to shorten the throw of the shifts. I could not be any happier with the results! Every shift I made today had me thinking “WOW that was easy, smooth AND QUICK”…
The shift arm has two holes for adjustability. The hold furthest from the spindle is slightly shorter than stock, with the hold closer to the spindle being much shorter than stock (This is the one I used). The results feel great. And I’m convinced that the ball linkage is tighter / smoother than the stock. You are suppose to only be able to use these with Sato rears (which is what I’m doing), but I don’t see why you would not be able to use them with stock rears (maybe someone can chime in why). Overall I highly recommend this to anyone that wants to shorten the throw of the shift lever in either regular or GP mode.
Old 06-19-2006, 03:16 AM
mrgrn's Avatar
NICE! i need that for my new rearsets.
how much are they retail?
Scott, please get me one of these
www.carbonpartz.net
www.blackdragonexhaust.net
Old 06-19-2006, 03:32 AM
nickbee's Avatar
Here is the link from the DK site:
http://www.kyleusa.com/catalog/rc51_...it_4699404.htm
Scott will hook you up!
Old 06-19-2006, 10:40 PM
mrgrn's Avatar
thank you
Scott, where are you?
www.carbonpartz.net
Old 03-06-2007, 11:06 PM
CBR400RR's Avatar
Originally Posted by mrgrn
thank you
Sorry I have been swamped there $49.00 shipped, let me know.
http://store.scottsms.com/
Old 03-06-2007, 11:51 PM
Mick's Avatar
Send a message via Yahoo to Mick
That sounds fantastic.
I'm a little humbled as to why Sport Bikes have such sloppy shifting With the exception of few that I've ridden, Honda's sport bikes seem to be trailing their MX lineup as far as grabbing gears. I'm almost appauled how stiff the shift engagements are..........not to mention how noisy the shift drum is.
I was also wondering if there was a cure to the long shift throws. I'm glad you posted this because I've been masterminding a plan to tighten the shift engagements up.
I'm pretty interested in the Factory Pro shift kit right now and that Sato shift arm sounds like a solid fix as well! I'd like to be able to retain my OE rearsets. So if for sure I can keep them with that shift arm I'd like to know
'00 RC51
Best mod: Sato exhuast
Worst mod: Maxxis Tires
'03 CR500AF
Best mod: Surf 'N Turf balanced crank
Worst mod: ICat
Old 03-06-2007, 11:57 PM
nickbee's Avatar
I only used this arm with the Sato rears. But I see no reason it would not work with stock rears.
The Sato rears makes everything very tight and smooth. No play in the lever like stock. And ball bearings on the pivots.
2002 RC51 (and I have the frame stickers to prove it!)
www.nickbee.com
Old 03-07-2007, 01:38 AM
RC51Stunna's Avatar
I didnt even realize that it was adjustable for the throw. THANKS!!
Nickbee, you should give the GP shift a try, most people who try it realize that it makes sense and dont go back..
I Got the part just to switch to GP but now I can shorten my throw too, thats sweet!
Stunna
Old 03-07-2007, 01:41 AM
nickbee's Avatar
Stunna
Ya Stunna I was thinking of giving the GP style a try this year. You'll love the short throw!
www.nickbee.com
Old 03-07-2007, 02:00 AM
Just call me JT ;-)
so this CANT be used with standard shift just to shorten it up?
2007 GSXR750 M4, Powercommander, Vortex, Woodcraft, MotoRX... more to come
Old 03-07-2007, 02:03 AM
nickbee's Avatar
If you read the DK site it says it can only be used with Satos. My satos were installed already when I got the new arm. I don't see any reason why it would not work with the stock rears. I say try it and let us know, Or maybe someone knows why it won't work with stock rears?
www.nickbee.com
Old 03-07-2007, 03:27 AM
Just call me JT ;-)
no no i will have sato's this week, i was wondering if they made this piece to shorten the shift however keeping stock pattern???
Old 03-07-2007, 04:13 AM
Smokngun's Avatar
You keep the stock pattern by mounting the arm so the shift rod is above the shift shaft. Reverse by mounting it below the shift shaft.
The arm is just splined and clamps on tight so you can put it in either position. This is how the Vortex unit worked on my friends Gixxer1000.
'04 RC-51
Old 03-07-2007, 04:18 AM
RC51Stunna's Avatar
My question is how do you know exactly where to mount the thing whichever way you put it. up or down.
is it as perfectly vertical as you can eyeball it?
Stunna
Old 03-07-2007, 05:00 AM
nickbee's Avatar
Stunna
it's called trial and error. PLace it where you think it works,, then ride. Then adjust the spindle you have it on or by adjusting the shaft for fine tunning. You'll get it just right any playing with it a bit. I am using it with sato rears and normal operation (NOT GP syle).
www.nickbee.com
Old 03-07-2007, 10:31 AM
Once bitten twice shy...
There is absolutely no reason to change to a GP shift pattern... many try it... and (true)many don't go back. No one ever tells you that they blew a tranny or a motor because they shifted wrong. Yes it happens and I've seen it happen on a borrowed bike during a race.
Mladin uses a regular shift pattern due an ankle injury, I think thats enough to sum up why its not a must do modification.
I think it should be realized by some.
YOU AIN'T GP MATERIAL SO LET IT GO.
Old 03-07-2007, 01:37 PM
RC51Stunna's Avatar
YA!! Dont do this mod if you have a left ankle injury OR your not familiar with the pattern and your RACING *ON SOMEONE ELSES BIKE!
Shoot for GP--> Land at Starbucks!
Stunna
Old 03-07-2007, 01:53 PM
wingnutt's Avatar
Talking you said mount
Stunna
Stunna,If you don't know how to mount it here's a link that will get you started NWS
WWW.ifithasapulseillmountit.com
_________________________
"03 RC"
and a new litter
I should REALLY wear a condum
Old 03-07-2007, 04:42 PM
nickbee's Avatar
I was going to try the GP shift for the hell of it. But the shifter is adjusted perfectly for me now so I might not mess with it.
But when the guy at Starbucks asks to ride my bike I could say, nope, it's a GP shifter, you can't hang!
www.nickbee.com
Old 03-08-2007, 01:14 AM
Dood... just get rid of the whole linkage and just order a shifter from a VFR800 and be done with it. $8-$12 says you'll be alot happier. Plus the feel of "stamping" the gears is more precise.
