replacing broken brembo brake lever - Speedzilla Motorcycle Message Forums
Old 06-18-2006, 12:22 AM
Default replacing broken brembo brake lever
Stuck at this point, need help in removing broken brembo brake lever and replacing with new one. The adjusting screw is supposed to come off by removing a tiny pin, I have no idea how to remove, the replacement lever comes with new pin and adjusting screw cap. PLS HELP!!!
Thanks,
Carlos
Old 06-18-2006, 12:30 AM
I've used a similar size drill bit, and VERY carefully, knock it in, thereby pushing the small pin out. Once half way out, I grab it with a pair of dikes and out it comes. Use the back of the drill bit, as it is flat.
Old 06-19-2006, 03:19 PM
Thanks! I'll try that. Wasn't sure and didn't want to f*** anything up.
Old 06-19-2006, 06:28 PM
Ray Tsai's Avatar
Also check the MC pin that is actuated by the handle., that one gets messed up pretty often when the lever hits the deck.
'05 ZX-6R (track)
'00 SV650 (track)
