Chocks for the trailer... - Speedzilla Motorcycle Message Forums
Old 04-12-2006, 05:49 PM
Default Chocks for the trailer...
Looking for something permanent for my new trailer. Just wondering what you guys and gals are using - I like cheap and easy!
I have a Baxley but dont have anything solid to put it up against to. I can permanently mount that but I will need 2 other mounts in the trailer. Rather have everything the same.
Thanks!
Track - 2003 Honda 600rr
Dirt - 2005 CRF 450
2005 CRF 50 - "for the kids"
NESBA #77
Old 04-12-2006, 06:34 PM
Anger managment patient
Chris, a friend of mine made one out of 3in aluminum angle. He bolted two flat pieces to the floor and sild the 90* 3in channel under them. Obviously he had tabs on the Channel to stop it from slidding all the way through. This way he could remove the 90 and have a near flat surface. He also had D-rings on the floor that simply lay down when not used. Very clean look when all done.
For the CR you can get some threaded turn buckels and hooks. Place the stand on the floor and mark the spot for the D-rings (6in out for the foot pegs). Then Place the bike on the stand and hook the pegs. It will not come off.
Old 04-12-2006, 06:50 PM
g-man's Avatar
Send a message via MSN to g-man
How many you need?
I've got three Pingle chocks (1 never used) that I will give you a great deal on.
Old 04-12-2006, 06:54 PM
http://www.blackandgray.com/main.htm
Andre make some real nice stuff.
njracer
BTW - I highly suggest the rear wheel chock with the quick release mounts.
Old 04-12-2006, 07:13 PM
Send a message via ICQ to Deton8d Send a message via AIM to Deton8d
ststands.com strapless stands are nice, but they're about as expensive as the sport chock.. They work really slick though, they hold the bike completely from the rear axle so you don't need a single tie down strap. They let you keep the bikes really close together too since you don't need tie downs.
--Greg
Old 04-12-2006, 08:15 PM
g-man's Avatar
The only problem I have with the strapless stands is you can't uses them if you have axle sliders installed.
Old 04-12-2006, 08:16 PM
Thanks guys!!
G-Man PM sent!
Dirt - 2005 CRF 450
NESBA #77
