need paint help - Speedzilla Motorcycle Message Forums
Go Back   Speedzilla Motorcycle Message Forums > Misc / Off Topic Area > The Lounge - Non-Motorsports Chat
Old 01-04-2005, 06:49 PM
Default need paint help
I have a little project for this week. I have a old cast iron piece that has to be painted.
1. do i need to remove all the old paint? if so what do i use.
2. any paint suggestions? this will be out side in the elements.
TIA for and help
Old 01-04-2005, 07:25 PM
Default Re: need paint help (mrgrn)
it always helps to stip it out and start off new. im not quite sure what you can use but i can ask a buddy of mine to see what you can use for that.
Old 01-04-2005, 08:15 PM
Default Re: need paint help (patluv2ride)
Thanx
it is a very old lawn jockey which i found and want to paint modern. The old lantern is shot and i got a new low-voltage copper one to go on there. My mother has some path lights i installed, and he would go great right at the edge of the path leading to the steps.
Old 01-05-2005, 12:18 AM
Best way to do cast iron is have it sand blasted (the place that you take it should know what the best way to blast it is).
Then use a good self etching primer and compatable paint on top of teh primer.
Old 01-05-2005, 02:28 AM
Default Re: (RP Racing)
Great tip
i know just the place for sandblasting, had forgotten about this guy
Old 01-05-2005, 02:31 AM
We used to strip the paint off valve covers with "Easy OFF" oven degreaser, or something like it. That with a little steel wool would take off even burnt on oil. Then we got a "dip tank" with industrial strength Chem dip. But if you left alluminum parts in overnight, they might not be there in the morning. very corrosive, also makes a very good weed killer. I think you can buy the chem dip in 5 gal cans at Home Depot, or maybe Checker. It may not be industrial strength but should do the trick for you.
Wormy
Old 01-05-2005, 04:57 AM
Default Re: (Wormy748)
