NEW!: Radial Brake Caliper Adapters for the RC51 ! - Speedzilla Motorcycle Message Forums
Go Back   Speedzilla Motorcycle Message Forums > Honda Sport Twins > Honda Sport Twins Classifieds
Old 04-21-2009, 05:28 AM
Rothmans's Avatar
Thumbs up NEW!: Radial Brake Caliper Adapters for the RC51 !
READY TO SHIP NOW!
All new Radial Brake Caliper adapters for the Honda RC51 SP1 and SP2!
Right now these sets ready to go are for SP2, but SP1 will be ready to ship in just a few days as well.
These are 108mm spacing and use the very common CBR 600/1000RR Radial Tokico caliper that you can find very reasonably priced on eBay all day long!
The kit comes with two radial brake adapters CNC'd from t-6061 billet aluminum and two fender mounts along with 4 oem Honda spacers that are used on the 600/1000RR with the Tokico calipers.
Price is just $259 per set!
NOW ALSO AVAILABLE IN BLACK! $271 per set SP1 / 2
Shipping in the USA is only $8 !
Worldwide shipping only $14 !
PayPal and Money order is fine, you can PM me or email:
info@RC51parts.com
Some more background and info:
All New Radial Brake Adapters for the RC51 !
Install how to:
Radial Brake Adapter Install How-to
THERMAE FRONT MOUNT RADIATORS NOW IN STOCK!
Honda RC51 Carbon Fiber Fenders, Huggers and Tail Cowls, Billet Top Triple clamps, original Honda accessories and LOTS MORE!!
TYGAUSA.COM (775) 293-TYGA M-F 9-6 Pacific
Check us out on FaceBook!
Old 04-21-2009, 05:29 AM
Rothmans's Avatar
Old 04-21-2009, 05:31 AM
Rothmans's Avatar
Old 04-21-2009, 06:08 AM
whitw wings's Avatar
Looking good man!
http://teampandaracing.com/
Old 04-21-2009, 06:36 PM
Default brake lines
will my Galfer superbike lines work with this setup? clint
Old 04-21-2009, 08:05 PM
MYZ1K's Avatar
Ride Naked!
Thats a good price! Is there a limited quantity? I'll be interested come next winter. Thanks
Old 04-21-2009, 08:25 PM
Ika-kun's Avatar
Sub-average Member
PM sent. Thanks!
Old 04-21-2009, 09:07 PM
Rothmans's Avatar
Clint, you are going to need a longer line to run these as the radial caliper is positioned lower than the stock one. I just set up a deal with Galfer so I will be offering new lines at (hopefully) much less than retail!
I will double measure everything later today and post up with some exact lengths required.
Old 04-21-2009, 09:08 PM
Rothmans's Avatar
I am going to try and always have these on hand at this price...I will list them on eBay, but for more money than here on "Zilla.
You should also be able to buy them shortly anytime online at RC51 Global Parts Source! !
Old 04-21-2009, 11:19 PM
mrgrn's Avatar
can i get a set in black for the sp1?
PM me the info Glen
www.carbonpartz.net
www.blackdragonexhaust.net
Old 04-23-2009, 06:30 PM
Rothmans's Avatar
Black anodizing in process now and will be ready in about 10-12 days!!!
Should also have a few SP1 kits ready to go out this week!!
Old 04-25-2009, 05:28 AM
Rothmans's Avatar
SP1 kits and black anodized versions will be ready May 6th!
You can PM Varium and MRGrn if you need Calipers as both have some they are selling!!
Old 04-25-2009, 07:06 AM
mrgrn's Avatar
Thanks Glen, top notch
OH, it is John and Mark too
www.carbonpartz.net
Old 04-26-2009, 04:22 PM
sbk_drew's Avatar
Exclamation Hardware?
Glen-
For SP-1 forks what length bolt will I need to bolt these to the fork leg?
Any idea on the c'bore dia. on the fender mounts?
I'd like to add them to my Ti order soon .
Old 04-26-2009, 07:06 PM
Originally Posted by sbk_drew View Post
Glen-
Fairly certain he is utilizing the stock fitments. So if you pull out your SP1 bolts currently being used you can get the correct dimensions. Its been a while since i've bothered with these figures so i'm just halfway guessing here....for exact measurements take the bolts to a hardware store and use their nut/bolt size scale.
fender bolt............m6 with a 1.25 pitch and length of 15mm(button head)
caliper bolt............m10 with a 1.25 pitch and length of 25mm(torx socket cap...but you can use a regular socket cap for replacement bolts)
Also, try the mircofiche as i think i recall seeing bolt sizes for these honda parts next to their part numbers.
Something to be aware of (especially for Ti. bolts) is their shoulder height. The smaller bolts will have a full thread, but the larger the bolt you go to the less chance you will find a full thread bolt. Most of these larger bolts have only a partial thread along the shaft of the bolt and the part where the thread ends and the rest of the bolt shaft begins is known as the shoulder.
This is actually the issue between the SP1 and SP2 bolts. So be sure to ask your bolt supplier if they can provide you with a full thread bolt. If not you will need to know the shoulder height of that bolt. If it is more than the height on your stock bolt is will not work. You'll run out of thread before the bolt can cinch down on the parts.
P.S. If you need a set of Ti caliper bolts i have a set that will probably work for you. Plus, these have already been predrilled for track prepping.
Old 04-26-2009, 11:12 PM
sbk_drew's Avatar
I currently have the caliper brackets mounted with M10 x 28 hex flg head screws right now and I believe they are full length thread. They should be long enough but not sure if the flange dia will fit the c'bores. Might have to switch to SHCS to fit them. I might be interested in the caliper screws so thanks.
Old 04-27-2009, 08:03 AM
sbk_drew's Avatar
Default OK, I was wrong........
The ones I have are not full thd but regardless, I don't believe the HFHCS shoulder will fit in the c'bore anyways so I'll need SHCS for that anyways. So a SHCS M10x25x1.25 will for the new mounts then?
Glen, do you know for sure the length of screw needed for mounting the calipers on your new mounts?
Old 04-27-2009, 07:09 PM
The SP2 uses a 35mm bolt. So if you use the 35mm bolt with his standard caliper set up for the SP2 then you are golden. It may be that the hex flange you currently use will be to large a base for the counter bored fender bracket Glenn will be having made for the SP1.....i think the flange is wider than the actual bracket width. So if you are resigned to buying bolts you mine as well go with the 35mm. Then again you may be able to find a local machine shop that could whittle down the proper sized bore for the current hex flange bolts you are using. Pretty sure you could buy another set of small Ti. bolts for the same or less though.
Old 04-27-2009, 07:19 PM
Rothmans's Avatar
Drew, Varium's posted up good info, but you can give me a call and we can go over any other questions to make sure it all works right!!
Thanks V!
Old 05-07-2009, 06:30 AM
Rothmans's Avatar
Ok, SP1 is now available and both SP1 and SP2 are now ready to ship in BLACK
If you would prefer the black anodized it is an extra $12, so $271 for the black version!
Here are some new photos!
