Turnone Airbox - Speedzilla Motorcycle Message Forums
Old 02-17-2012, 11:58 AM
Default Turnone Airbox
Considering getting a Turnone Airbox for my SP2
I see there is an all carbon version and a carbon / GRP version. I assume the only difference is the carbon one is slightly lighter but is it by much and noticeable ?
Old 02-17-2012, 12:10 PM
tuurio's Avatar
NO,not noticeable! both versions are a huge upgrade over the stock heavy airbox, go for the cheapest version. This saves you money for your needed power commander.
Old 02-17-2012, 07:26 PM
Hi tuurio thanks for the reply which confirms excatly what I was thinking.
The question it does raise in my mind though is, why if there is no weight gain or performance gain from the all carbon airbox over the carbon / GRP airbox why does it exsist seeing as it costs $120 more is it purely the bling factor ?
Old 02-17-2012, 09:18 PM
tuurio's Avatar
There's not really a bling factor as you can't see the airbox from the outside.
If money is no problem, buy a carbon there is a slight weight gain and every gram of weight saving will count.
Maybe the carbon version is a little stronger.
But the grp/carbon is reinforced where needed with carbon layers.(around the throttlebody holes and sidewalls).
Maybe Brett can chime in and tell you the weight difference between the 2 versions.
Old 02-18-2012, 06:27 AM
nobody's Avatar
Sorry to jack the thread but I Googled and can't seem to find the answer.
Where do I find said TurnOne air box??
Old 02-18-2012, 01:36 PM
gts455's Avatar
You can contact Brett on here (Turnone)
You can contact scott who sometimes has a few in stock
Honda, RC51, SP1, SP2, Carbon, Airbox, with, Filter
or sometimes brett has some on ebay. Just type in Turnone. Doesn't look like he has any for sale right now.
Old 02-18-2012, 03:24 PM
nobody's Avatar
Ty...
Old 02-18-2012, 07:12 PM
Default Box
I have a full cf one for sale if ur looking
Old 02-19-2012, 01:41 AM
nobody's Avatar
How much
Old 02-19-2012, 01:42 AM
nobody's Avatar
How much?......
Old 02-19-2012, 02:01 AM
F/S SP1 parts-Turn1,Mori,Fox,
'99 VTR-F: Ported & decked heads, lwt flywhl, JE pistons, Carillo rods, bal'd crank, DLC-coated bits, Akra exh, DJ kit, Flo-Comm, modded airbox, BMC filter, billet stacks, HRC throttle, stick coils; FP shift kit; Brembo radial MCs, F4i calipers, Braketech rotors, SRJL pads, lwt rr rotor; 900RR forks, GV kit, OMT triples, Apex risers, Ohlins shock and strg damper, braced swinger; PVM Mg rims, ceramic brgs, SP2 cluster, Pazzos, Samco hoses, SPAL fan, Li battery, Ti & carbon bits...
Old 02-19-2012, 03:29 PM
Default Price
275 plus shipping
