Sp1 stalling ! - Speedzilla Motorcycle Message Forums
Old 08-15-2011, 12:07 AM
RC51 LV's Avatar
Default Sp1 stalling !
I have a 2001 SP1 with 38.000 miles on it ! And today when at a stop sign it just cut off , i started it again and drove off however this has never happed to me ! It was reading 210 deg on the temp and was not blinking any FI numbers ! Has anyone had this problem ? Thank you for looking
Old 08-15-2011, 01:51 AM
rc racer D.O.G. Ind
Check your sidestand switch
Old 08-15-2011, 03:01 AM
RC51 LV's Avatar
I will check that right now !
Old 08-15-2011, 04:20 AM
RC51 LV's Avatar
The side stand switch looks good when i was checking it !
Old 08-15-2011, 06:55 AM
b.miller123's Avatar
Member (Large)
Check all your grounds, and check for loose fuses and connectors, check for rubbing wires under the back of the fuel tank and on the left side of the subframe.
Old 08-15-2011, 08:45 PM
irishaggression's Avatar
I speed up for corners
Fuses. Also check the battery cables where they connect to the battery. Vibrated loose and connection gets weak all the time on my old sp1
inbred sp1/sp2
Old 08-29-2011, 12:57 PM
if you are still having the issue try getting the codes off the ecu to see what it throws at you. I had a similar issue with my bike. At first it happened rarely then started to do it more and more. turned out the main crimp went bad.
http://www.speedzilla.com/forums/rc5...nder-load.html
if the bike is throwing a bunch of codes like mine was check the wiring diagram to see if they are all on the same ground if so its mostly like the same issue I had.
