Front Mount Radiators for Everybody! - Page 2 - Speedzilla Motorcycle Message Forums
post #21 of 234 (permalink) Old 07-13-2011, 03:24 PM
oh god, my bank account just officially filed a restraining order on me! lol soon as i refill my play budget i know my next purchase. I bet it will make changing the front plug a bitch though!
forsaken82 is offline
post #22 of 234 (permalink) Old 07-13-2011, 07:06 PM
vanessa's Avatar
well done guys, great job. great price!
vanessa is offline
post #23 of 234 (permalink) Old 07-13-2011, 07:38 PM
SWEET!!! Front mounts here i come. I just need to make some extra change then i will be ordering a set. thanks Glen for spending my money before i have it.
post #24 of 234 (permalink) Old 07-13-2011, 09:13 PM
Member (Large)
b.miller123's Avatar
Wow, those look great Glenn!
Any info on what radiator hoses will be needed? Looks like 2 short 90's, a longer 90, 2 45's and a short straight section.
Now I know what I want for christmas.....
b.miller123 is offline
post #25 of 234 (permalink) Old 07-13-2011, 10:05 PM
Turnone's Avatar
Excellent work !!
The kit looks good and will look ever better when it's hanging of the front of my bike.
Order has been placed ,payment has been made !!
TurnOne Carbon Australia
P.O.Box 25,
Bundoora 3083
Victoria.
AUSTRALIA.
Ph: 0416355287
email:
Turnone is offline
post #26 of 234 (permalink) Old 07-13-2011, 10:36 PM
Sub-average Member
Ika-kun's Avatar
Originally Posted by Rothmans View Post
Some more photos, but first a BIG THANKS to Terence ( IKA-KUN ) on here that did an early install and track testing that provided us with very valuable info and feedback.
It was my pleasure, Glenn. FYI, I just ran again at California/AAA/Fontana Speedway last Sunday with an ambient temp of around 93*F and my SP2 never got hotter than 210*F, and I was seriously spanking her ALL DAY LONG! No fans!!! (I don't even have my Spal installed yet...because I'm lazy.)
My hat's off to you! Nothing but love!
Now only if you guys could make a small rock/debris guard to keep the lower part of the vertical radiator minty!
2005 VTR SP2 - Not stock.
1989 RC31 - Not very stock, either.
Ika-kun is offline
post #27 of 234 (permalink) Old 07-14-2011, 01:48 AM
RCVTR's Avatar
That's great, Glenn! I'm going to need some!
210 deg. on a 93 deg. day sounds too high. I don't get that hot with air scoops and Mori fins with stock rads. Might have to build a shroud to keep the pressure up on the front side.
Stainless steel screen wired to the front works well to prevent damage from rocks and tire chunks.
'02 RC51 track bike
RCVTR is offline
post #28 of 234 (permalink) Old 07-14-2011, 06:46 AM
Sub-average Member
Ika-kun's Avatar
Not when you're running a lean map...
Ika-kun is offline
post #29 of 234 (permalink) Old 07-14-2011, 04:20 PM
mrgrn's Avatar
same thing i was thinking i was hoping these would bring them temps below 200 with no fans.
1990 RC30
2001 RC51
2006 R1
2002 TL1000r
mrgrn is offline
post #30 of 234 (permalink) Old 07-14-2011, 04:29 PM
wingnutt's Avatar
Do you have a clue what a lean map does to the water temp ???
"03 RC"
and a new litter
I should REALLY wear a condum
wingnutt is offline
post #31 of 234 (permalink) Old 07-14-2011, 04:40 PM
mrgrn's Avatar
is this a thread about front mount temps and a question i have asked or is it about a super lean mod?
let's talk about the reason for running a bike in 93 degree heat with a super lean map
what is the normal temps of these rads with no fans on a street bike?
1990 RC30
2001 RC51
2006 R1
2002 TL1000r
mrgrn is offline
post #32 of 234 (permalink) Old 07-14-2011, 04:44 PM
No Please Explain Ole Great One!!!
(pure Sarcasm)
What AFR are you at on your current map IKA?
post #33 of 234 (permalink) Old 07-14-2011, 04:48 PM
mrgrn's Avatar
(pure Sarcasm)
and what would be the point? 2 HP
1990 RC30
2001 RC51
2006 R1
2002 TL1000r
mrgrn is offline
post #34 of 234 (permalink) Old 07-14-2011, 05:47 PM
Member (Large)
I smell jealousy, or is that something else?
post #35 of 234 (permalink) Old 07-14-2011, 05:49 PM
I did just fart.
post #36 of 234 (permalink) Old 07-14-2011, 06:04 PM
mrgrn's Avatar
Originally Posted by Akilldema View Post
I did just fart.
was it gas with a oily discharge
1990 RC30
2001 RC51
2006 R1
2002 TL1000r
mrgrn is offline
post #37 of 234 (permalink) Old 07-14-2011, 07:42 PM
Hey Neil.... This is such a basic thing I can't actually believe you're asking for pictures..
You just go to your local Hardware store and by whatever screen mesh that floats your boat.... and
afix it with safety wire as Jimmy said... It's as easy as putting gas in your gas tank![/QUOTE]
Jeff,
I like pictures!!!
Neil.
neilzakleigh is offline
post #38 of 234 (permalink) Old 07-14-2011, 09:12 PM
MrGrn's posts stink of jealousy. Guy resells Taiwanese knockoffs and someone comes out with a top notch product and he's losing his mind over it. Love it!
why don'y you do yourself a favor and put me on ignore
Jami6989 is offline
post #39 of 234 (permalink) Old 07-14-2011, 09:14 PM
wingnutt's Avatar
So when tuning two strokes tword lean you get much hotter combustion chaimber temps and the water temp increases also.
"03 RC"
and a new litter
wingnutt is offline
post #40 of 234 (permalink) Old 07-14-2011, 10:52 PM
JBs_SP3's Avatar
Temps will obviously vary depending on ambient temperature, setup and what the bike is used for. I made these radiators for myself primarily as I had the Hord engine to cool. Total square surface area is actually a little less than OEM but the cores are 32 mm thick, way thicker than stock. Also, as we know, a significant portion of the stock side mount rads are shrouded by the engine hangers.
I've not had an opportunity to run these front mounts on an OEM motor, I used them to break in the Hord motor and they performed brilliantly. Naturally the motor developed a lot of heat new so I removed the thermostat and fitted 2 x 4" SPAL fans to the lower rad. Now that it's run in a bit I'm not seeing temps much above about 77*C (170*F) on the open road and the fans barely kick in at the lights. As I don't track the bike I'm planning on re-installing the thermostat and then seeing if 1 x 4" fan is sufficient. Terence was kind enough to test the rads with the thermostat in place and so far he's not running a fan. Obviously if the bike is stationary for long enough with the motor running it will overheat.
JBs_SP3 is offline
Human Verification
