Frame stamping - Speedzilla Motorcycle Message Forums
post #1 of 3 (permalink) Old 02-10-2010, 04:38 PM Thread Starter
Frame stamping
Has anyone stamped numbers on the rc chassis if so how hard is it, Im thinking of buying a new chassis but I need to stamp the numbers from my bike and will the steel stamping kit work or do i need one for aluminum?
hotglue is offline
post #2 of 3 (permalink) Old 02-12-2010, 05:01 PM
As far as i know Honda is the only manufacturer that will do this. If you buy a new frame through a Honda dealer then you can have the factory stamp the new one for you. Its a program Honda does through their dealers. You'll need to provide proof of ownership and the neck of the frame with a good vin plate will need to be turned in. Most dealers won't like to have to ship a complete frame so you may be asked to cut the neck off. Should be done anyway if there is going to be another frame out there with potentially the same vin stamp.
The neck with good vin plate, proof of ownership paperwork, and some legalese paperwork for Honda gets shipped off to Japan and 3-4 weeks later you should receive a call from the dealer to come and pick up your new frame. The good thing about doing it this way is you get to pick which year frame to buy. If you wanted the rare 04 frame then you can have that with your vin on it. May be the only one in the country to have a set up like that.
varium is offline
post #3 of 3 (permalink) Old 02-12-2010, 11:26 PM
Clone
QUIZZY's Avatar
Not the exact process. You do need your frame and a title. Also the frame has to be in stock at one of the parts warehouses in the U.S. If it is not then you have to have a special request made by American Honda and then they take over the process from there. RC's are getting harder and harder to get parts for through Honda. Especially body panels. Good luck with this it is a royal PITA.
Champions Honda Kawasaki
QUIZZY is offline
Human Verification
