socket size help....axle nuts - Speedzilla Motorcycle Message Forums
Old 09-28-2006, 11:34 PM
nycstripes's Avatar
Meatball's Dad
Default socket size help....axle nuts
Hey fellas,
Sears has a tool sale going on, I am updating my tool set and replacing some missing items. I am at the office and do not have access to the bike. I need the correct size of the front and rear axle nuts.
thanks
Ken
__________________________________________________ __________________________________________________ _________________________
”Fathom the hypocrisy of a government that requires every citizen to prove they are insured…but not everyone must prove they are a citizen.”- Ben Stein
ΜOΛΩΝ ΛΑΒΕ
www.OATHKEEPERS.ORG
Old 09-28-2006, 11:36 PM
Krasiejay's Avatar
rear axle is 17mm
**edit. its 22mm**
chain tighteners are 10 and 12 mm
dont know about the front
Old 09-28-2006, 11:37 PM
Krasiejay's Avatar
Originally Posted by Krasiejay
rear axle is 17mm
I should say "i think" about the rear axle. numbers off the top of my head
Old 09-28-2006, 11:43 PM
Rigor's Avatar
RC51-less Member
Rear: 1-1/4" or 32mm
Front: 22mm
Old 09-28-2006, 11:48 PM
Krasiejay's Avatar
Front: 22mm
damn, i just shouldn't open my mouth anymore
TXRC51fatboy's Avatar
Damn Asshat
front 22mm
rear 32mm
chain tigheners 12 front 10 rear
04 RC51
President of The Troy Bayless Haterz Club
Old 09-28-2006, 11:53 PM
nycstripes's Avatar
Meatball's Dad
thanks gents, tools are on order.
Ken
ΜOΛΩΝ ΛΑΒΕ
www.OATHKEEPERS.ORG
Old 09-29-2006, 12:50 AM
Cutaway's Avatar
Default Torque specs?
Hey while we are at it....do you guys have the torque specs for both? As well as the pinch bolts?
Thanks....Josh
www.speedcell.org
www.durbahn-usa.com
Good luck is for novices, bad luck is for everyone. Rely on your skills.....You control em!
Old 09-29-2006, 04:54 AM
Damn Asshat
Common Torque Values
Front wheel Socket SizeBrake caliper mount bolt (loc-tite)22 ft/lbs
Brake pad pins 13ft/lbs
caliper bracket to forks (loc-tite)36ft/lbs
main axle43ft/lbs
axle pinch bolts16ft/lbs
front brake disk bolt14ft/lbs
steering stem nut 00-0176ft/lbs30mmsteering stem nut 02-03101ft/lbs41mm
triple clamp (upper & lower)20ft/lbs
Rear wheel main axle nut94ft/lbs32mmsprocket nuts47ft/lbs
front sprocket40ft/lbs
rear brake caliper bolt17ft/lbs
MISC exhaust pipe joint nut9ft/lbs
fuel feed hose banjo bolt16ft/lbs
fuel feed hose nut16ft/lbs
footpeg holder bolts20ft/lbs
Mori Link bolts33ft/lbs
oil drain plug22ft/lbs
oil filter 19ft/lbs
courtesy or rc51.org
04 RC51
Old 09-29-2006, 05:50 AM
Cutaway's Avatar
Default Thanks...
Hey thank...but I feel like a dumbass...I already had those from .ORG posted in my garage...
Thanks again...
Josh
www.speedcell.org
www.durbahn-usa.com
