sprocket & chain? - Speedzilla Motorcycle Message Forums
Old 05-17-2006, 06:49 PM
Default sprocket & chain?
I have a question, I have a sp1 and it needs to have the sprockets and chain replaced, can anyone give me an idea of what chain and sprocket to get, I know I am done with a aluminum sprocket, and I have a 520 chain on it which I hope to replace with a 530 chain, I was going to go with Afam, but if anyone has any other suggestions I would apreciate it. Thanks....also what is a good sprocket upgrade from stock?
Old 05-17-2006, 09:42 PM
jazz's Avatar
Send a message via AIM to jazz Send a message via MSN to jazz
Stay with the 520 chain.....less weight and all that....
I have seen on here before that 16/41 is ideal.....I run 15/42 but i don't ride on the road anyway....
even so, stay with the 520 chain ..!
For street riding in the uk.....dunno dude but would definately use a 42 rear sprocket even if you keep a 16 front....
Hope that is some help!!!!
Cheers
Jazz
VTR 1000 SP1 #31
www.teamvtracing.moonfruit.com
life should be measured not by the amount of breathes you take but by the amount of times you breath is
taken away.........
You begin your riding career with an empty bag of experience and a full bag of luck. The trick is to fill the bag of experience before you empty the bag of luck.....
Old 05-17-2006, 09:45 PM
area51racer's Avatar
Chain: DID brand in the 520 size (ERV2 or ERV3)
Sprockets: AFAM or Renthal
530 is heavier than 520 so why switch back?
520 setups are hard to find steel sprockets for. Maintain the piss out of the chain and your aluminum sprockets will last longer.
Gearing choices. These seem to work well: 16/42 or the 15/41 is the most popular.
bcr495's Avatar
definitely stay with the 520. Afam makes a steel front and rear spocket. I got tired of going thru rear spockets also
also call Scott(cbr400rr), he can hook with the Afam steel spockets.
2005 RC51
2000 ZX9R(daily driver)
Old 05-17-2006, 09:52 PM
jazz's Avatar
Jesse K.....
Like what was said on another thread.....go to bandcexpress they are good....I brought a couple of different sprockets from them (front and rear)....
520......
520......
520......
520......
520......
520......
520......
stay with it.......
Cheers
Jazz
VTR 1000 SP1 #31
taken away.........
Old 05-18-2006, 05:46 PM
Licarbv's Avatar
Turgid Member
Send a message via AIM to Licarbv
In day to day street riding is 520 that diff than 530? Is it purely weight? or less rotational mass?
Old 05-18-2006, 06:01 PM
I only ride street, and I like the 520. Rotional mass decrease, also decrease in unsprung weight on the rear axle - rear shock has an easier job to do.
I'm running 15-41/520 right now, and it's a good all-round choice. You might consider 15-42/520, it's another popular choice. Great fun trying to keep the front tire on the ground in the low gears. Wonderful problem to have.
Old 05-18-2006, 06:03 PM
Licarbv's Avatar
Turgid Member
I am running 520 15/41 now... I too am gonna try out 15/42...
I lube the chain once a month
too often or not enough...
Garage kept, no rain rides...
Old 05-18-2006, 06:06 PM
Great White Northerner
"And a man comes on the radio,
to say how white my shirts can be.
But he can't be a man cause he doesn't use,
a 520 chain like me."
(With apologies to Mick and Keith)
On the street, I'll venture it makes no difference. Some will say it does.
Again, my
Old 05-19-2006, 02:01 AM
BLU-BY-U's Avatar
I lube mine every 300 to 400 miles.
<img src=http://speedzilla.com/forums/signaturepics/sigpic5999_2.gif border=0 alt= />04 RC51,Sato rearsets,Sato lows,Sato Ti hangers,Scotts Damper,Flapper,PCIIIUSB & Hub & LCD,K&N,15/42,Goodridge,CRG,SCORE= Deer-O,RC51-2,R1-1
