No start -- key on, no FI light, no fuel pump whirring - Speedzilla Motorcycle Message Forums
Old 04-26-2006, 06:07 PM
Default No start -- key on, no FI light, no fuel pump whirring
As the title says, this happened yesterday once, and again this morning:
  • All fuses OK. In neutral, kill switch in run position.
  • Key on, lights light up, tach does self test, etc.
  • No FI light and no fuel pump whirring.
  • Starter turns, but engine doesn't catch.
I flick the kill switch a few times, the FI light flickers on and off, and finally comes on like normal and the fuel pump primes the system. The bike fires right up.
After running around the block, I kill the bike with the key and restart just fine.
Could it be a bad kill switch?
2002 RC51, mostly stock
Old 04-26-2006, 06:30 PM
SIR's Avatar
SIR SIR is offline
Yep!! Sounds like it to me.
Old 04-26-2006, 06:50 PM
RVTMAVERICK's Avatar
TOP GUN Instructor
Talking Yepper! By George I Think Hes Got It!
+1.......................As in me too!
You can open up the switch and take a look at the wires for corrosion?
Clean and spray some WD or better yet Silicone spray. Good Luck!
Old 04-27-2006, 03:48 AM
DBDMotorsports01RC51's Avatar
Send a message via Yahoo to DBDMotorsports01RC51
Thumbs up Check the relays....
Try this......
There are 2 relays in the rear of the bike. I believe one is the tip over sensor relay, and the other is the fuel pump/system relay. One of those relay's could have gone bad.
Mine did the same thing. Everything was working fine, but it would she wouldn't kick over.
I know that the relay costs like 30 bucks.
The true RC51 owners know the heritage and history of what the HRC stamped into the engine cases mean.
2001 RC51-CF High Mount Jardines, Power Commander IIIr, Vortex Rear Sets, GP Shift, Scotts Steering Damper, Corbin Saddle, Goodridge SS Front Lines , Galfer Rear SS Line, Renthal 15/41, DID GOLD 520, 4mm front fork drop, and a happy rear ride height.
1997 916s-Loaner Bike.....Just The Termignoni Ti Full System.
Old 04-27-2006, 08:18 AM
Hoovenater's Avatar
You can use the Headlight relay to troubleshoot problems with the Fuel cut relay and the bank angle sensor relay (all 3 are the same part). Swap the two in the trunk with the headlight relay, one at a time and test the bike.
Follow the battery cables and check all the connections and cables. It sounds like a battery problem, but it could be a relay or the kill switch itself.
Hoov.
CRA # 200
Thankfully sponsored by;
LP USA
Sportbike Track Gear
