Is there a better photo? Like one thats out a bit? Asside from the tach being almost to nothing the helmet position doesnt look right to me. Maybe its the angle.
7000 rpms apexing a corner on a 250 hp motogp v-5 bike. Sounds accurate considering the fact that the more you lean the lower the profile of the rear tire, causing the rpms to drop.
Uhh, RPM's go UP when you lean in. The diameter at the tire patch gets smaller and therefore the RPM goes higher. Geez, I ride a Duc and I know that one!
Actually your RPMs rise as you lean over. You are going from a larger circumference to a smaller circumference. I think it is in Twist of the Wrist II that explains this. When you are on a 600 for example and you are almost to redline at the end of a straight that is followed by a high speed sweeper, you will have to back off of the throttle by 500 or so RPM so when you lean the bike over, the RPM will rise, you stay constant on the throttle through the turn and as you bring the bike back upright, you get back on the gas. This should keep you right below the rev limiter the whole way through the end of the straight, sweeper and exit.
I worked in a pet store and people would ask how big I would get. Rodney Dangerfield
- He might not be riding at race pace
- It might be a tight slow corner (relatively speaking)
- He might have made a mistake and been a gear too high?
- And maybe he's doing everything right and still going along at 7k rpms; its the RC211V, that machine shreds the gnar
Tom
2000 Honda RC51 - Ti Sato mid-mount, pcIII, braided brake lines.
Here's the full pic, He's obviously on a hot lap.
I was amazed at how low the revs are. I bet that thing pulls like a fookin train at low revs. All the magazine guys that have ridden the 211 say that its amazing how easy it is to ride it fast. But thinking about the what the dyno chart for the 211 must look like, it probably makes about 120 horsepower in the middle revs.
looks just about right IMO. ever seen a rc30 graph? pull, straight up. also keep in mind that is a V5 and pulls like no telling and revs like a raped ape. i bet a split second later that thing lurched 4000 rpms
Nope, try again....the smaller diameter of the edge of the tire means you will have higher engine rpm given the same vehicle speed.
Man, you guys must have a lot of time on your hands to worry about this.
__________________ "...let us not ignore the truth among ourselves, that we are the aggressors and they defend themselves. The country is theirs, because they inhabit it, whereas we want to come here and settle down."
David Ben-Gurion (the father of Israel) "When fascism comes to America it will be draped in a flag and holding a cross." Sinclair Lewis I pledge allegiance to the flag of the United States of America, and to the republic for which it stands. One nation, indivisible, with liberty, and justice for all.
